coq-club - Re: [Coq-Club] termination when branching with fmaps
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] termination when branching with fmaps
  • Date: Fri, 19 Feb 2021 18:07:02 +0100
Hi,
> Finite maps are based on finite functions which allow such nested
definitions,
> You can find an example in the doc:
There is actually an example about tree in the header
https://github.com/math-comp/math-comp/blob/17dd3091e7f809c1385b0c0be43d1f8de4fa6be0/mathcomp/ssreflect/finfun.v#L24
the depth function is simply:
Inductive tree : Type := node n of tree ^ n.
Fixpoint depth (t : tree) : nat :=
match t with node n br => (\max_(i <- codom (depth \o br)) i).+1
end.
Laurent
