- From: Vincent Semeria <vincent.semeria AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] True arithmetical proposition not provable
- Date: Sun, 20 Jun 2021 23:02:22 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vincent.semeria AT gmail.com; spf=Pass smtp.mailfrom=vincent.semeria AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi1-f180.google.com
- Ironport-hdrordr: A9a23:y0eUpqFxRKMb+CiCpLqE0ceALOsnbusQ8zAXPiFKOGVom6mj/fxG885rsCMc5AxhOk3I3OrwW5VoIkm8yXcW2/h0AV7KZmCP01dAbrsD0WKI+UyGJ8SRzJ866U6iScRD4R/LYGSSQfyU3OBwKbgd/OU=
- Ironport-phdr: A9a23:l3jusBUeDzO5OnPFyyz5fMqmEfTV8KwmVTF92vMcY1JmTK2v8tzYMVDF4r011RmVBNSdsKkbwLOP7OjJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglVgDexe71/IRu0oAneq8UanIlvIbstxxXUpXdFZ/5Yzn5yK1KJmBb86Maw/Jp9/ClVpvks6c1OX7jkcqohVbBXAygoPG4z5M3wqBnMVhCP6WcGUmUXiRVHHQ7I5wznU5jrsyv6su192DSGPcDzULs5Vyiu47ttRRT1jioMKjw3/3zNisFog61brhCuqRxxzYDXfY+bKuZxc7jHct8GX2dMRNpdWzBDD466coABD/ABPeFdr4TlqFQOrB2+ChWyC+Pp1j9Dm2L40rM/0+s/CwHG3RYvFM8JvXTKrdX1MrsdXv6zzKnU1znDdO1Z2TLj54jScxAuu+qBXb11ccXLyEkvExnJgUmXqYzgJj6Y0PkGvGeH4eR6T+2vl3InpB9rojip3sohl4jEiIwax13H+yt13Ik7KN+lRENlfdOpEIZcuj2EOoZ2Xs4vXWJltTs1x7AHtpC1cygExYk6yhPbd/CKfIuF7xT+X+ifJjd4gWhqeLO5hxuq7EigzOz8WtCv0FlQtCVFiN3MuWoL1xPO8MSIV+Vy80G80jiMzwDe8v9ILVwwmKbBKJMswqQ8mocSvEnBBCP6hUb7gLOQe0454Oan8f7nba/jppKEN497lAX+MqM2l8y6G+s4MwwOU3Gc+eS9ybHv5EP5TKhJg/EqiKXZv5faJcMUpq69HQBZyJos6xG6Dzu+0dQYm2cILE5ddR6Zk4TkP0vCLfP4APulnlihkTVmy+rbMrDiHpnBNn3Dn63gfbZ55U5c0g0zzdVH6pJKC7EBJu78VVH3tNzEFBM5KBK7w+P5B9Vn14MRQ3mCAqCcMKzIsF+I4vgjLPWLZI8QoDr9MeQq5+byjX8lnl8QZbWm3ZwOaHyhAvtmJ1iZbmH3j9caEWYKuxI+Q/bwhF2DVz5TfXeyULgm6jE1EoL1RbvEE4uqmfmK2DqxNpxQfGFPTF6WQlnycIDRZfYKYy+UPodanzkJT7moA9s/1BeluQnmjaFqK+fO+yQwupfq1dwz7OrWw0JhvQdoBtiQhjneB1p/mXkFEmdeNEVXrkl0y1PF2q990aQw/TN76PZAUwN8PpnZnbUS4zHaXwvAepKOSQ/jTIz2WXc+SdU+x9JIaEF4SY3Ksw==
Hi Dominik,
Gödel's incompleteness theorem applies to any theory that extends arithmetic. Here I choose Coq as that extended theory, and InterpProp is what I imagine does the extension. So more arithmetical formulas are provable than with just the Peano axioms.
I am actually not sure about this either. How do we do when we apply Gödel's incompleteness to ZFC? I guess arithmetical propositions are likewise interpreted as ZFC formulas where variables become quantified over the set of natural numbers.
On Sun, Jun 20, 2021, 22:40 Dominik Kirst <dominik.kirst AT cs.uni-saarland.de> wrote:
Hi Vincent,could you also explain in what sense InterpProp can be seen as the provability predicate for PA? To me it looks like the usual Prop-valued evaluation of formulas in the standard model. If you formulate the provability predicate instead as a concrete inductive predicate just relying on the syntax, you end up with a relation that can indeed be shown strictly weaker than InterpProp. In fact, InterpProp is easily shown negation-complete if you assume LEM on Prop while negation-incompleteness of the provability predicate has already been mechanised a couple of times, not only in Coq.We’ll actually be presenting one of these mechanisations at ITP in two weeks, maybe the paper is interesting for you as you also mentioned ZFC:Best wishes,DominikOn 19. Jun 2021, at 10:22, Vincent Semeria <vincent.semeria AT gmail.com> wrote:Gödel's incompleteness theorem asserts that the consistency of first-order theories (such as Peano arithmetic or ZFC) is an arithmetical formula which is true in the standard model of arithmetic, but which is not provable by the theory in question.Assuming LPO, I defined interpretations of arithmetical formulas in Coq, both in bool and in Prop, as shown below. I imagine that Coq's consistency is an arithmetical formula that would be interpreted to true by InterpBool. And not provable would mean that its InterpProp is not provable (as a Prop). However I also proved that InterpBool and InterpProp are equivalent, by an easy induction on the formula. Then I don't see how a true arithmetical formula would be not provable. Is there a problem in my interpretations, or maybe is it because Coq is a second-order logic, in which incompleteness manifests differently ?Fixpoint InterpProp (varValues : nat -> nat) (p : PeanoProp) {struct p} : Prop :=
match p with
| Eq a b => InterpTerm varValues a = InterpTerm PS varValues b
| Not q => ~InterpProp varValues q
| And q r => InterpProp varValues q /\ InterpProp varValues r
| Or q r => InterpProp varValues q \/ InterpProp varValues r
| Implies q r => InterpProp varValues q -> InterpProp varValues r
| Forall n q (* i.e. forall Xn, q *)
=> forall m:Inat PS, InterpProp (SetVarValue n m varValues) q
| Exists n q
=> exists m:Inat PS, InterpProp (SetVarValue n m varValues) q
end.Axiom LPO : forall un : nat -> bool, { exists n:nat, un n = true } + { forall n:nat, un n = false }.Fixpoint InterpBool (varValues : nat -> nat) (p : PeanoProp) {struct p} : bool :=
match p with
| Eq a b => Nat.eqb (InterpTerm PeanoNat varValues a)
(InterpTerm PeanoNat varValues b)
| Not q => negb (InterpBool varValues q)
| And q r => andb (InterpBool varValues q) (InterpBool varValues r)
| Or q r => orb (InterpBool varValues q) (InterpBool varValues r)
| Implies q r => implb (InterpBool varValues q) (InterpBool varValues r)
=> if LPO (fun m:nat => negb (InterpBool (SetVarValue n m varValues) q))
then false else true
| Exists n q
=> if LPO (fun m:nat => InterpBool (SetVarValue n m varValues) q)
then true else false
end.Lemma InterpBoolPropEquiv : forall (p : PeanoProp) (varValues : nat -> nat),
(InterpBool varValues p = true <-> InterpProp PeanoNat varValues p).
Proof.induction p. ...Qed.
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, (continued)
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Ralf Jung, 06/24/2021
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Marco Servetto, 06/24/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Louis Garde, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, roconnor, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, roux cody, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Vedran Čačić, 06/30/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Vincent Semeria, 06/20/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Dominik Kirst, 06/22/2021
