Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable
- Date: Thu, 24 Jun 2021 11:00:27 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-hdrordr: A9a23:ICJ3aqlOrHTaEcoD3J/1ybr8RbXpDfN/imdD5ihNYBxZY6WkfqeV7ZAmPH7P+VMssRQb8+xoV5PufZrjz+8X3WBvB8bEYOCLggWVxfhZnO3fKmTbalTDH41mpMVdmspFZeEYZGIS5a3HCWGDf+rIq+PmzEnHv4bjJ2MGd3ATV0hC1XYzNi+rVm1wS01rAZI4Ed616MYvnUvaRV0nKuS9CT0+WfTZrdH3hIvrCCR2fSLO+2O1/E6VAKmRKWnl4v8KOQk/vovLHQL+4nLEDkvIiYDL9vZ07R6i071m3Nf60p95CMaBitcYJwjtjgrAXvUTZ1WV1gpF0t1GADwR4azxS/xLBbUG15s6FFvF1icENmPboUATA5CJ8y7QvZMLy/aJDA4HNw==
- Ironport-phdr: A9a23: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
Ah, actually it's in the same paper, and doesn't even need "SRP" (whatever
that is):
There’s an explicit 748-state Turing machine that halts iff ZF is inconsis-
tent. Thus, assuming ZF is consistent, ZF cannot prove the value of BB(748).
; Ralf
On 24.06.21 10:56, Ralf Jung wrote:
One of my favorite examples of incompleteness is the value of the busy beaver function for "large" inputs, where I think "large" has been brought down below 1000 at this point.
See §4.2 of <https://www.scottaaronson.com/papers/bb.pdf> (but the bound of 7910 states there has been improved since then):
There’s an explicit 7910-state Turing machine that halts iff the set theory
ZF + SRP (where SRP means Stationary Ramsey Property) is inconsistent. Thus, assuming that
theory is consistent, ZF cannot prove the value of BB(7910).
Kind regards,
Ralf
On 24.06.21 04:48, Marco Servetto wrote:
I'm more and more confused, but now I have an example that may help to
clarify (and ends up hitting non-standard numbers too)
-One of the typical examples for Propositions that may not be provable
is termination of programs:
-lets have "halt(p) = n" a partial function from program->nat, that returns
the
number of steps the program p takes to terminate.
- For all terminating programs, their execution trace is a valid and
finite 'proof of termination'
- For some programs, there is no proof of neither
Exists n: halt(p)=n nor not Exists n: halt(p)=n
-Those programs do not terminate, otherwise we would have a
termination proof using their execution trace.
-Question1: Where is the 'model' that defines 'truth' in my reasoning above?
-Question2: If I can somehow write down one of those programs, I
could add as an axiom that Exists n: halt(p)=n, and the system should
still be unable to prove true=false, right? is then such 'n' a non
standard number? Is the reason we keep talking about non standard
numbers connected with this question/issue?
Marco.
On Thu, 24 Jun 2021 at 06:44, Ken Kubota <mail AT kenkubota.de> wrote:
This is exactly my position!
(I read this after writing the other email.)
All presentations of Goedel's theorems tacitly (implicitly) convey a specific philosophical approach without being conscious of the relativity of the approach as a whole when relying on a metatheory.
Philosophically, relying on a metatheory is even self-contradictory.
Kind regards,
Ken Kubota
____________________________________________________
Ken Kubota
https://doi.org/10.4444/100
Am 22.06.2021 um 11:11 schrieb Pierre-Marie Pédrot <pierre-marie.pedrot AT inria.fr>:
What does that mean? Truth is always relative to your meta-theory so you
can't say much about "satisfaction in the meta" without explicitly
specifying the rules of your meta.
I personally really hate the phrasing of Gödel's incompleteness theorem
as "there are unprovable true statements" because it's implicitly
referring to the meta and confusing the reader about some grand and
transcendental notion of "truth" when this does not exist. Except maybe
when you're a Girard fan and / or some neo-Popperian believer, in which
case you may claim that Π01 formulae are falsifiable in the only
standard model we have, a.k.a. our local universe, and thus there is
some well-behaved notion of truth for these (but not above).
Incompleteness is really a boring theorem that can be phrased purely in
terms of provability without any irrelevant references to truth,
anchovies or hairy Schwarzschild black holes.
Website: https://people.mpi-sws.org/~jung/
- Re: [Coq-Club] True arithmetical proposition not provable, (continued)
- Re: [Coq-Club] True arithmetical proposition not provable, Peter LeFanu Lumsdaine, 06/22/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Vincent Semeria, 06/22/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Pierre-Marie Pédrot, 06/22/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Andrei Popescu, 06/22/2021
- [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Ken Kubota, 06/23/2021
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Marco Servetto, 06/24/2021
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Pierre Courtieu, 06/24/2021
- Re: [Coq-Club] Tacit implications in Goedel's theorems II – Re: True arithmetical proposition not provable, Ralf Jung, 06/24/2021
- Re: [Coq-Club] True arithmetical proposition not provable, roconnor, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Louis Garde, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, roux cody, 06/29/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Vedran Čačić, 06/30/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Marco Servetto, 06/30/2021
- Re: [Coq-Club] True arithmetical proposition not provable, Vincent Semeria, 06/30/2021
