- From: Dominique Larchey-Wendling <Dominique.Larchey-Wendling AT loria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proper subset relation well-founded?
- Date: Mon, 05 Dec 2022 07:26:05 +0100
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none
Hi Mukesh,
Your "subset" relation is included in the relation length xs < length ys so it is wf by combination of wf_incl, wf_inverse_image and lt_wf. Decidability of eq is *not* needed.
However, it does not properly characterize proper subsets IMHO. Indeed you have eg [1;1] is a proper subset of [1;2;2] but also of [1;1;1].
I would suggest using "there is a point in ys which is not in xs" (rather than the length criteria) to witness strict decrease. Also wf but somewhat harder to prove. I can point to some code if needed.
Best,
Dominique
Le 5 décembre 2022 06:50:10 GMT+01:00, mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> a écrit :
Hi everyone,Is this (proper) subset relation is well-founded? Based on my understand, I believe the answer is no (and maybe we need more assumptions), but I am happy be proven otherwise. You can see the complete code [1].Definition finset (A : Type) := list A.(* proper subset *)Definition subset {A : Type} (xs ys : finset A) : Prop := (∀ x, In x xs -> In x ys) ∧ (List.length xs < List.length ys). (* for proper subset *)Lemma well_founded_subset {A : Type} :(∀ x y : A, {x = y} + {x ≠ y}) ->well_founded (@subset A).Proof.intro Hdec. unfold well_founded. induction a as [| ah al Iha]. + econstructor; intros ? [Hyl Hyr]. simpl in Hyr; nia. + (* Induction Hypothesis peeling *) pose proof (Acc_inv Iha) as Ha. (* transitivity *) econstructor; intros xt Hx. (* I can unfold one more time, but will I get anything meaningful? *) econstructor; intros yt Hy. (* case analysis *) destruct (List.In_dec Hdec ah yt) as [Hb | Hb]. ++(* In ah yt *) pose proof (subset_member _ _ _ Hb Hy) as Hc. (* ah ∈ xs so I can write xs = xsl ++ [ah] ++ xsr. From Hx : subset xt (ah :: al) I can infer: subset (xsl ++ xsr) al. But there is no way I can establish: subset yt (xsl ++ xsr) for transitive and induction hypothesis to work. My conclusion is: it's not provable but happy to be proven wrong. If it's not provable, can we make subset relation well founded? *) admit. ++ admit. Admitted.Best,Mukesh
- [Coq-Club] Proper subset relation well-founded?, mukesh tiwari, 12/05/2022
- Re: [Coq-Club] Proper subset relation well-founded?, Dominique Larchey-Wendling, 12/05/2022
- Re: [Coq-Club] Proper subset relation well-founded?, mukesh tiwari, 12/05/2022
