Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU with Windows and Visual C++ port?
Archives de la liste
Chronologique Discussions
  • To: Cédric Augonnet <cedric.augonnet@inria.fr>
  • Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU with Windows and Visual C++ port?
  • Date: Fri, 25 Feb 2011 14:36:22 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
(I have attached a patch for the README, noting its good to update the Video drivers as older versions have bugs interfering with StarPU and OpencCL).
After updating the drivers on this machine, I can run examples from the source tree (e.g. examples\basic_examples\variable)
I guess I would like the README to discuss the process of building StarPU on Windows for use with OpenCL (from NVidia/ATI) and for using StarPU from Visual Studio.
The current SVN builds are failing to generate .def files on Windows. (see below)
Configured as follows
./configure --with-opencl-dir=/c/prog/NVOpenCL --disable-cuda --disable-cpu --enable-verbose --enable-debug --enable-opencl
$ make install
Making install in src
make[1]: Entering directory `/c/prog/StarPU/starpu/trunk/src'
make[2]: Entering directory `/c/prog/StarPU/starpu/trunk/src'
make[3]: Entering directory `/c/prog/StarPU/starpu/trunk/src'
test -z "/usr/local/lib" || /bin/mkdir -p "/usr/local/lib"
/bin/sh ../libtool --mode=install /bin/install -c libstarpu.la '/usr/local/lib'
libtool: install: /bin/install -c .libs/libstarpu.lai /usr/local/lib/libstarpu.la
libtool: install: /bin/install -c .libs/libstarpu.a /usr/local/lib/libstarpu.a
libtool: install: chmod 644 /usr/local/lib/libstarpu.a
libtool: install: ranlib /usr/local/lib/libstarpu.a
make install-exec-hook
make[4]: Entering directory `/c/prog/StarPU/starpu/trunk/src'
/bin/install -c .libs/libstarpu.def /usr/local/lib
/bin/install: cannot stat `.libs/libstarpu.def': No such file or directory
make[4]: *** [install-exec-hook] Error 1
make[4]: Leaving directory `/c/prog/StarPU/starpu/trunk/src'
make[3]: *** [install-exec-am] Error 2
make[3]: Leaving directory `/c/prog/StarPU/starpu/trunk/src'
make[2]: *** [install-am] Error 2
make[2]: Leaving directory `/c/prog/StarPU/starpu/trunk/src'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/c/prog/StarPU/starpu/trunk/src'
make: *** [install-recursive] Error 1
On 24/02/2011 20:21, Cédric Augonnet wrote:
Hi,
We have one of our users who used StarPU that way already, his code was developed under VS, and he linked with a .dll that was provided from mingw. Within the PEPPHER project, Movidius simulator is another example of code developed under VS and that used StarPU.
Cédric
On 24/02/2011 20:17, George Russell wrote:
Hi,
It may be possible to make Mingw compiled .dll's that are usable from within Visual Studio, and that can also link with user code compiled in Visual Studio, and with OpenCL driver stacks for Windows; however, at present this is completely untested and may not work for some unforseen reason.
I'd certainly be interested in testing such a combination, if the requisite wrappers around the Mingw compiled code could be made.
Cheers,
George
On 24/02/2011 19:55, Cédric Augonnet wrote:
On 24/02/2011 19:38, Samuel Thibault wrote:
George Russell, le Thu 24 Feb 2011 18:31:57 +0100, a écrit :
I'd like to query if there is a possibility of StarPU being officially ported
to Windows via the Visual Studio development tools e.g. to compile on Windows
without the use of GCC and a Unix compatibility layer. The main motivation of
this would be to allow the use of StarPU on Windows with the NVidia / AMD /
Intel OpenCL SDKs on GPU / CPU, and our compilers that generate OpenCL.
I'm not sure why we need to build StarPU with Visual Studio to make it
usable in Visual Studio? Can't we just provide appropriate .h / .def
/ .lib .visual-studio-stuff files? We already do provide .h, .def and
.lib, I thought that was enough for Visual Studio to be happy (I have to
admit I have never actually used Visual Studio myself, however).
The issue is that we don't use windows in our everyday work, and thus we
won't keep StarPU compilable by MSVC ourself. The MinGW approach permits
to at least share the compiler, which keeps a lot of compatibility
issues with MSVC away. Yes, we could make nightly MSVC builds of StarPU
to spot MSVC issues early, but doing it on the whole code will be quite
some work, while doing it just on the interface (.h, .def) should be
quite easy to keep working.
Samuel
Hello,
Indeed, even within the PEPPHER framework, people would not have to modify StarPU, so that if we manage to provide some standard configuration (e.g. supporting OpenCL + CUDA), there is little point in making it possible to recompile StarPU from VS. Everything that was promised in the PEPPHER project should be doable without modifying StarPU's sources (apart from fixing bugs of course).
Keeping the code compatible to the numerous version of VS is tedious, and since none of actually even has a VS installed, it's clear that it would go unmaintained very soon so we cannot realistically promise such as thing. I'm also unfamiliar with VS, but does it make a different to take a .dll or some code compiled from VS in terms of function name completion and so on ?
That said, this confirms we really need to provide a nightly build .dll/.def/.lib or whatever would help windows users.
Best,
Cédric
Index: README
--- README (revision 3243)
+++ README (working copy)
@@ -127,6 +127,10 @@
copy c:\cuda\lib\cufft.lib c:\cuda\lib\libcufft.lib
copy c:\cuda\lib\OpenCL.lib c:\cuda\lib\libOpenCL.lib
+- Update the video drivers to the latest stable release available for your
+ hardware. Older drivers contain bugs that cause OpenCL support in StarPU to
+ hang or exhibit incorrect behaviour.
|| V. Trying ||
Haut de le page
