Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: George Russell <george@codeplay.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU with Windows and Visual C++ port?
- Date: Sat, 26 Feb 2011 17:12:09 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
George Russell, le Fri 25 Feb 2011 14:36:22 +0100, a écrit :
> The current SVN builds are failing to generate .def files on Windows.
> (see below)
> Configured as follows
> ./configure --with-opencl-dir=/c/prog/NVOpenCL --disable-cuda
> --disable-cpu --enable-verbose --enable-debug --enable-opencl
I guess that the config.log will tell you that MSVC' lib.exe wasn't
found by configure. I've added to README that it needs to be in PATH
for configure to find it.
Samuel
- [Starpu-devel] StarPU with Windows and Visual C++ port?, George Russell, 24/02/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, Samuel Thibault, 24/02/2011
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, Cédric Augonnet, 24/02/2011
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, George Russell, 24/02/2011
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, George Russell, 25/02/2011
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, Samuel Thibault, 26/02/2011
- Re: [Starpu-devel] StarPU with Windows and Visual C++ port?, Nathalie Furmento, 25/02/2011
