Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Asynchronous Task execution problem
- Date: Tue, 01 Mar 2011 18:56:05 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, Please try to memset your codelet after its allocation to initialize fields to 0. Otherwise StarPU will access "model" and "power_model" pointer fields that aren't initialized. I haven't compiled your code so it may not be the only issue. Please tell us if you still face segfaults. Cheers Sylvain PS: I vote for a starpu_codelet_create() as I already encountered this issue in my code. Le 01/03/2011 18:01, Usman Dastgeer a écrit : Hello, Maybe I am doing some mistake but I am facing this problem (Segmentation fault) while working with a big application. I tried to simulate this problem in a reasonably short example (attached). Please look into it and tell my why it does not work. Thanks in advance! -- Usman _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] Asynchronous Task execution problem, Usman Dastgeer, 01/03/2011
- Re: [Starpu-devel] Asynchronous Task execution problem, Sylvain HENRY, 01/03/2011
- Message indisponible
- Re: [Starpu-devel] Asynchronous Task execution problem, Samuel Thibault, 02/03/2011
- <Suite(s) possible(s)>
