Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Usman Dastgeer <usman.dastgeer@liu.se>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Asynchronous Task execution problem
- Date: Wed, 2 Mar 2011 01:17:22 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Usman Dastgeer, le Tue 01 Mar 2011 18:02:25 +0100, a écrit :
> codelet = new starpu_codelet();
As Sylvain mentioned, does this fill the structure with zeroes? It needs
to, else uninitialized fields will bring issues.
> // Asynchronous, submits to starpu with a single handle for both read and
> write (STARPU_RW)
> void submitTasks(starpu_data_handle arr_hdl)
> struct starpu_task *task = starpu_task_create();
> task->cl = codelet;
> codelet->nbuffers = 1;
> // Asynchronous, submits to starpu with separate handle for input and
> output.
> void submitTasks(starpu_data_handle arr_hdl,starpu_data_handle out_hdl)
> task->cl = codelet;
> codelet->nbuffers = 2;
This is not supposed to work if you submit several tasks with both
functions: the task you have submitted earlier will still be pointing
at the same codelet structure, and when StarPU will actually run it, it
will try to fetch two buffers since you have just changed nbuffers to 2,
thus crashing. You need to use two codelet structures, one per number
of arguments. This is actually also important for performance models:
since you have a different behavior in both cases, you need different
performance models.
gamuel
- [Starpu-devel] Asynchronous Task execution problem, Usman Dastgeer, 01/03/2011
- Re: [Starpu-devel] Asynchronous Task execution problem, Sylvain HENRY, 01/03/2011
- Message indisponible
- Re: [Starpu-devel] Asynchronous Task execution problem, Samuel Thibault, 02/03/2011
- <Suite(s) possible(s)>
