Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU: OpenCL do not work well
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Leo Li <luli757@student.liu.se>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU: OpenCL do not work well
  • Date: Mon, 14 Mar 2011 15:10:51 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
It seems you are using a old version of StarPU. Could you please update to a newest version, and let us know if the problem is still there.
You can get StarPU latest nightly snapshot from the following page: http://starpu.gforge.inria.fr/testing/
Thanks,
Nathalie
On 14/03/2011 11:42, Leo Li wrote: Hi,
Sorry for late response.
I can not find code " clGetKernelWorkGroupInfo(...)" in vector_scal_opencl.c, so I can not have this value reported to you.
I replace the line with your suggested code, and my problem solved in the case. Thank you.
Sorry again for late responese.
On Mon, Mar 14, 2011 at 10:43 AM, Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
-------- Original Message --------
Date: Sat, 12 Mar 2011 00:47:53 +0100
To: starpu-devel@lists.gforge.inria.fr
Hi,
For debugging purpose, could you add the following line in examples/basic_examples/vector_scal_opencl.c just after the clGetKernelWorkGroupInfo(...):
fprintf(stderr, "Work group size: %ld\n", local);
This should tell you what the block size used is. If it doesn't divide 2048, is equal to 0 or is greater than 1024, the error is here. Please report this value to us.
Anyway, for this particular case, replacing:
err = clEnqueueNDRangeKernel(queue, kernel, 1, NULL, &global, &local, 0, NULL, NULL);
with
err = clEnqueueNDRangeKernel(queue, kernel, 1, NULL, &global, NULL, 0, NULL, NULL);
in the same file, should solve the issue. (I didn't try this fix)
Cheers
Sylvain
Le 11/03/2011 21:34, Leo Li a écrit :
Hi, everybody
My name is Lu Li. I am a master student at Linkoping University, Sweden.
I currently do my master thesis based on StarPU under professor
Christoph W. Kessler. And I got a problem, could someone help me.
Thanks.
My problem is that  if I run vector_scale example after setting
environment variables:
export STARPU_NOPENCL=1
export STARPU_NCUDA=0
export STARPU_NCPUS=0
I will get an error(See attached invalid.jpg, the screenshot). StarPU
works fine with CPU and CUDA.
I have run some test on my OPENCL device.(Result shown in attached
file: oclDeviceQuery.txt) Seems Opencl device is ok. So There might be
some configuration problem on StarPU.
Could someone help me. I can offer more detail if needed. Thank you.
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Faithful
Lu Li
Contact: +46704759692
Haut de le page
