starpu-devel@inria.fr
Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Subject: Re: [Starpu-devel] StarPU: OpenCL do not work well
- Date: Sat, 26 Mar 2011 12:24:17 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=Y14s1KyZzAQGaFslAUCwj3OyvlVEesu3GYQIXWwYW7a/fF/dHv0Cdc/OYbWCv+UJtx Hg3lgEFxhJNBgotkhor1ADeuCUQWC2OgRaDBCUHFcOMAzPg4jBWuTNaNVBUnBYkwUtha On9LIoEhCJ5+2pO9lrZrcW0KCySBfqkBvZhPg=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
- Resent-date: Sat, 26 Mar 2011 12:26:38 +0100
- Resent-from: Nathalie Furmento <nathalie.furmento@labri.fr>
- Resent-message-id: <4D8DCD6E.1030909@labri.fr>
- Resent-to: starpu-devel@lists.gforge.inria.fr
- Resent-user-agent: Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.9.1.16) Gecko/20110303 Iceowl/1.0b1 Icedove/3.0.11
Hi,Nathalie
I have a question about StarPU, does it support dynamic task creation,
what I mean is to submit another StarPU task within one StarPU task.
If it supports, could you give me an example code? Or could you check
where my example code got wrong in attached?
Thank you very much.
On Tue, Mar 15, 2011 at 10:58 AM, Leo Li <luli757@student.liu.se> wrote:
> I think it works fine with the new version.
> I attached the test result.
> Thank you so much.
> On Tue, Mar 15, 2011 at 9:55 AM, Nathalie Furmento
> <nathalie.furmento@labri.fr> wrote:
>> On 15/03/2011 09:53, Nathalie Furmento wrote:
>>> On 14/03/2011 22:08, Leo Li wrote:
>>>> Now I have an old version of StarPU installed, if I want to install the
>>>> newest version, do I have to uninstall the old version first, if so,
>>>> could
>>>> you offer me a tutorial on how to uninstall old version?
>>> You just need to delete the directory where you installed StarPU. I
>>> suppose you specified --prefix=some_directory when you called configure to
>>> build and install StarPU. Deleting the directory specified above will
>>> delete
>>> StarPU.
>>> Regards,
>>> Nathalie
>> If you still have the build directory (the one you started configure, make,
>> make install from), you can also call "make uninstall" from that directory.
>> it will delete for you all the installed files.
>> Cheers,
>> Nathalie
> Faithful
> Lu Li
> Contact: +46704759692
Faithful
Lu Li
send.zip
Description: Zip archive
- [Starpu-devel] Fwd: Re: StarPU: OpenCL do not work well, Nathalie Furmento, 14/03/2011
- Message indisponible
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Nathalie Furmento, 14/03/2011
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Leo Li, 26/03/2011
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Nathalie Furmento, 26/03/2011
