Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Leo Li <luli757@student.liu.se>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU: OpenCL do not work well
- Date: Sat, 26 Mar 2011 13:30:23 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello Leo,
it is possible to submit a task within a callback. Make sure the task is not synchronous as blocking calls are not allowed within a callback.
Please send any further request to starpu-devel (it will increase your chances to get a appropriate answer).
Regards,
Nathalie
On 26/03/2011 12:24, Leo Li wrote:
Hi,Nathalie
I have a question about StarPU, does it support dynamic task creation,
what I mean is to submit another StarPU task within one StarPU task.
If it supports, could you give me an example code? Or could you check
where my example code got wrong in attached?
Thank you very much.
On Tue, Mar 15, 2011 at 10:58 AM, Leo Li<luli757@student.liu.se> wrote:
I think it works fine with the new version.
I attached the test result.
Thank you so much.
On Tue, Mar 15, 2011 at 9:55 AM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
On 15/03/2011 09:53, Nathalie Furmento wrote:
On 14/03/2011 22:08, Leo Li wrote:If you still have the build directory (the one you started configure, make,
Now I have an old version of StarPU installed, if I want to install theYou just need to delete the directory where you installed StarPU. I
newest version, do I have to uninstall the old version first, if so, could
you offer me a tutorial on how to uninstall old version?
suppose you specified --prefix=some_directory when you called configure to
build and install StarPU. Deleting the directory specified above will delete
StarPU.
Regards,
Nathalie
make install from), you can also call "make uninstall" from that directory.
it will delete for you all the installed files.
Cheers,
Nathalie
Faithful
Lu Li
Contact: +46704759692
- [Starpu-devel] Fwd: Re: StarPU: OpenCL do not work well, Nathalie Furmento, 14/03/2011
- Message indisponible
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Nathalie Furmento, 14/03/2011
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Leo Li, 26/03/2011
- Re: [Starpu-devel] StarPU: OpenCL do not work well, Nathalie Furmento, 26/03/2011
