Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Performance metric
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: ASD D <ajitsdeshpande@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Performance metric
  • Date: Fri, 4 Nov 2011 18:34:08 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
ASD D, le Fri 04 Nov 2011 18:29:45 +0100, a écrit :
> 2] Then, I see following files(performance model files) -  .starpu/sampling/
> codelets/vector_scale.mymachine and vector_scale_power.mymachine, generated
> in
> my folder after execution of the app under starpu -
>   having content as below.
That's it. As explained in part 6.3 (Performance of codelets) of the
documentation, you can use starpu_perfmodel_display to get the
information a bit more clearly, but it's about the same information.
> # hash          size            mean            dev             sum
> sum2            n
> 870a30aa        8192            4.338900e+01    0.000000e+00
> 4.338900e+01
> 1.882605e+03    1
So your task took 43µs for size 8KB. If you run it several times, you
will get the average and standard deviation.
Samuel
Haut de le page
