Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, ASD D <ajitsdeshpande@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Performance metric
- Date: Mon, 7 Nov 2011 15:59:05 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Defined a structure starpu_perf_model_t provided its address in the
.model field of the starpu_codelet structure, i have.
Now after execution of my app, it generated the performance model
files for the codelet with metrics mentioned for the CUDA worker I
have.
But once it is created after first execution run, no matter how many
times i run my app after that, the number in the performance model
file not change.
How does one achieve the average numbers in the performacne model
files by running the app multiple times and getting the deviation and
sum metrics there?
thank you.
-AD
On Mon, Nov 7, 2011 at 3:09 PM, Samuel Thibault
<samuel.thibault@ens-lyon.org> wrote:
> ASD D, le Mon 07 Nov 2011 14:53:25 +0000, a écrit :
> > In am able to get the performance model files in
> > .starpu/sampling/codelets,
> > which have metrics, for the basic_examples (e.g. vector_cal) but when I
> > run my
> > own application, I do not seem to get any performacne model files, which
> > would
> > tell me the task execution metrics for my application. Any macro i need to
> > enable while configuring to get this?
> Did you define a history-based performance model as described in 4.8
> Performance model example? Also, you need to use a scheduler which makes
> use of performance models, such as heft or dmda.
> Samuel
- [Starpu-devel] Performance metric, ASD D, 04/11/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Performance metric, Samuel Thibault, 04/11/2011
- Re: [Starpu-devel] Performance metric, ASD D, 05/11/2011
- Re: [Starpu-devel] Performance metric, ASD D, 07/11/2011
- Re: [Starpu-devel] Performance metric, Samuel Thibault, 07/11/2011
