Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, ASD D <ajitsdeshpande@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Performance metric
- Date: Sat, 5 Nov 2011 09:32:22 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thank you Samuel.
-Ajit.
On Fri, Nov 4, 2011 at 5:34 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASD D, le Fri 04 Nov 2011 18:29:45 +0100, a écrit :
> 2] Then, I see following files(performance model files) - .starpu/sampling/That's it. As explained in part 6.3 (Performance of codelets) of the
> codelets/vector_scale.mymachine and vector_scale_power.mymachine, generated in
> my folder after execution of the app under starpu -
> having content as below.
documentation, you can use starpu_perfmodel_display to get the
information a bit more clearly, but it's about the same information.
So your task took 43µs for size 8KB. If you run it several times, you
> # hash size mean dev sum
> sum2 n
> 870a30aa 8192 4.338900e+01 0.000000e+00 4.338900e+01
> 1.882605e+03 1
will get the average and standard deviation.
Samuel
- [Starpu-devel] Performance metric, ASD D, 04/11/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Performance metric, Samuel Thibault, 04/11/2011
- Re: [Starpu-devel] Performance metric, ASD D, 05/11/2011
- Re: [Starpu-devel] Performance metric, ASD D, 07/11/2011
- Re: [Starpu-devel] Performance metric, Samuel Thibault, 07/11/2011
