Archives de la liste
Re: [Starpu-devel] [PATCH] src/sched_policies: add starpu_sched_policies_common.{c, h}, that will contain code that can easily be shared between schedulers.
Chronologique Discussions
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [PATCH] src/sched_policies: add starpu_sched_policies_common.{c, h}, that will contain code that can easily be shared between schedulers.
- Date: Tue, 06 Mar 2012 18:51:32 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 03/06/2012 06:36 PM, Samuel Thibault wrote:
Cyril Roelandt, le Tue 06 Mar 2012 18:31:34 +0100, a écrit :
With this patch, _heft_push_task is smaller and uses less local variables.
_starpu_compute_best_fitness() will probably be easily reusable in pheft and
dmda.
pheft would be hard, as there are also the parallel tasks, where fitness
would have to be very different.
dmda should just be merged with heft. The difference is there just to
choose whether to enable data awareness, priorities, etc. but ideally it
should just be merged into one scheduler, with options to enable or
disable.
So, rather than trying to factorize parts of the code, should we :
1) Clean up heft (basically, get rid of the endless functions that use a gazillion parameters and local variables).
2) Make sure heft can do dmda's job, adding options etc.
3) Once it's all been tested, remove dmda.
Cyril.
- Re: [Starpu-devel] [PATCH] src/sched_policies: add starpu_sched_policies_common.{c, h}, that will contain code that can easily be shared between schedulers., Samuel Thibault, 06/03/2012
- Re: [Starpu-devel] [PATCH] src/sched_policies: add starpu_sched_policies_common.{c, h}, that will contain code that can easily be shared between schedulers., Cyril Roelandt, 06/03/2012
