Archives de la liste
- To: <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10
- Date: Tue, 5 Jun 2012 18:03:19 +0300
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
I’m having some trouble building the library on Ubuntu 11.10 32bit, GCC 4.6.1. I get undefined symbol errors for the OpenCL primitives provided by the OpenCL library. I have checked the library path and it is provided correctly.
I suspect the errors may be due to the fact that the -lOpenCL gets placed before the file that is using the library function calls in the linker command line. I noticed that the -l directives should be placed after the file in order for the linking to work properly.
Could there be some change in the makefiles in order to avoid this issue?
Best regards, Alin Dobre
- [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 05/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Cyril Roelandt, 06/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 08/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Samuel Thibault, 08/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 11/06/2012
