Archives de la liste
[Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back".
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back".
- Date: Tue, 16 Oct 2012 23:45:05 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
trunk/src/sched_policies/fifo_queues.c | 13 ++++++++++---
1 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/trunk/src/sched_policies/fifo_queues.c
b/trunk/src/sched_policies/fifo_queues.c
index 33d1cd6..4c07690 100644
--- a/trunk/src/sched_policies/fifo_queues.c
+++ b/trunk/src/sched_policies/fifo_queues.c
@@ -57,9 +57,16 @@ int _starpu_fifo_push_task(struct _starpu_fifo_taskq
*fifo_queue, pthread_mutex_
_STARPU_PTHREAD_MUTEX_LOCK(sched_mutex);
- _STARPU_TRACE_JOB_PUSH(task, 0);
- /* TODO: if prio, put at back */
- starpu_task_list_push_front(&fifo_queue->taskq, task);
+ if (task->priority > 0)
+ _STARPU_TRACE_JOB_PUSH(task, 1);
+ starpu_task_list_push_back(&fifo_queue->taskq, task);
+ else
+ _STARPU_TRACE_JOB_PUSH(task, 0);
+ starpu_task_list_push_front(&fifo_queue->taskq, task);
fifo_queue->ntasks++;
fifo_queue->nprocessed++;
1.7.9
- [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 3/7] Heft: use a scheduler-specific fifo rather than pushing tasks directly to the workers' local tasks., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 7/7] Handle bundles in deque_modeling_policy_data_aware.c., Cyril Roelandt, 16/10/2012
