Archives de la liste
Re: [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function.
Chronologique Discussions
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Cyril Roelandt <cyril.roelandt@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function.
- Date: Fri, 19 Oct 2012 17:42:21 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Cyril Roelandt, le Tue 16 Oct 2012 23:45:22 +0200, a écrit :
> /* Sometimes workers didn't take the tasks as early
> as we expected */
> fifo->exp_start = STARPU_MAX(fifo->exp_start,
> starpu_timing_now());
> + /* XXX: next 3 lines: should we use
> exp_end[worker][nimpl] instead of
> + fifo->exp_end, as it's done in heft ? */
> fifo->exp_end = fifo->exp_start + fifo->exp_len;
Yes. It's not useful to update the fifo exp_end before we actually push
the task.
Samuel
- [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 3/7] Heft: use a scheduler-specific fifo rather than pushing tasks directly to the workers' local tasks., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 7/7] Handle bundles in deque_modeling_policy_data_aware.c., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 7/7] Handle bundles in deque_modeling_policy_data_aware.c., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 1/7] src/sched_policies/heft.c: use an array of _starpu_fifo_taskq* rather than multiple global variables., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Samuel Thibault, 19/10/2012
- Re: [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Cyril Roelandt, 22/10/2012
- [Starpu-devel] [PATCH v2 1/6] src/sched_policies/heft.c: use an array of _starpu_fifo_taskq* rather than multiple global variables., Cyril Roelandt, 22/10/2012
- [Starpu-devel] [PATCH v2 2/6] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Cyril Roelandt, 22/10/2012
