Archives de la liste
[Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function.
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function.
- Date: Tue, 16 Oct 2012 23:45:08 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
It is almost the same as the compute_all_performance_predictions() function
defined in heft.c (it does not support task bundles yet, though).
It is used by dmda and dmdas.
.../deque_modeling_policy_data_aware.c | 141
1 files changed, 94 insertions(+), 47 deletions(-)
diff --git a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
index 96c38bc..7cc4c57 100644
--- a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
+++ b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
@@ -20,11 +20,21 @@
#include <limits.h>
+#include <core/perfmodel/perfmodel.h>
+#include <core/task_bundle.h>
#include <core/workers.h>
#include <sched_policies/fifo_queues.h>
#include <starpu_parameters.h>
+#ifndef DBL_MIN
+#define DBL_MIN __DBL_MIN__
+#endif
+#ifndef DBL_MAX
+#define DBL_MAX __DBL_MAX__
+#endif
static unsigned nworkers;
static struct _starpu_fifo_taskq *queue_array[STARPU_NMAXWORKERS];
@@ -395,76 +405,77 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
return push_task_on_best_worker(task, best, model_best, prio);
-static int _dmda_push_task(struct starpu_task *task, unsigned prio)
+static void compute_all_performance_predictions(struct starpu_task *task,
+ double
local_task_length[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
+ double
exp_end[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
+ double *max_exp_endp,
+ double *best_exp_endp,
+ double
local_data_penalty[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
+ double
local_power[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
+ int *forced_worker, int *forced_impl)
- /* find the queue */
- struct _starpu_fifo_taskq *fifo;
- unsigned worker;
- int best = -1;
- /* this flag is set if the corresponding worker is selected because
- there is no performance prediction available yet */
- int forced_best = -1;
- double local_task_length[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double local_data_penalty[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double local_power[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double exp_end[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double max_exp_end = 0.0;
- double fitness[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double best_exp_end = 10e240;
- double model_best = 0.0;
- //double penality_best = 0.0;
+ int calibrating = 0;
+ double max_exp_end = DBL_MIN;
+ double best_exp_end = DBL_MAX;
int ntasks_best = -1;
+ int nimpl_best = 0;
double ntasks_best_end = 0.0;
- int calibrating = 0;
/* A priori, we know all estimations */
int unknown = 0;
+ unsigned worker;
- unsigned best_impl = 0;
unsigned nimpl;
+ starpu_task_bundle_t bundle = task->bundle;
for (worker = 0; worker < nworkers; worker++)
+ struct _starpu_fifo_taskq *fifo = queue_array[worker];
for (nimpl = 0; nimpl < STARPU_MAXIMPLEMENTATIONS; nimpl++)
- fifo = queue_array[worker];
+ if (!starpu_worker_can_execute_task(worker, task,
nimpl))
+ /* no one on that queue may execute this task
+ continue;
/* Sometimes workers didn't take the tasks as early
as we expected */
fifo->exp_start = STARPU_MAX(fifo->exp_start,
starpu_timing_now());
+ /* XXX: next 3 lines: should we use
exp_end[worker][nimpl] instead of
+ fifo->exp_end, as it's done in heft ? */
fifo->exp_end = fifo->exp_start + fifo->exp_len;
if (fifo->exp_end > max_exp_end)
max_exp_end = fifo->exp_end;
- if (!starpu_worker_can_execute_task(worker, task,
nimpl))
- /* no one on that queue may execute this task
- continue;
enum starpu_perf_archtype perf_arch =
starpu_worker_get_perf_archtype(worker);
- local_task_length[worker][nimpl] =
starpu_task_expected_length(task, perf_arch, nimpl);
+ unsigned memory_node =
starpu_worker_get_memory_node(worker);
//_STARPU_DEBUG("Scheduler dmda: task length (%lf)
worker (%u) kernel (%u) \n", local_task_length[worker][nimpl],worker,nimpl);
- unsigned memory_node =
- local_data_penalty[worker][nimpl] =
starpu_task_expected_data_transfer_time(memory_node, task);
+ if (bundle)
+ STARPU_ABORT(); /* Not implemented yet. */
+ else
+ local_task_length[worker][nimpl] =
+ local_data_penalty[worker][nimpl] =
+ local_power[worker][nimpl] =
starpu_task_expected_power(task, perf_arch,nimpl);
double ntasks_end = fifo->ntasks /
starpu_worker_get_relative_speedup(perf_arch);
if (ntasks_best == -1
- || (!calibrating && ntasks_end < ntasks_best_end)
/* Not calibrating, take better task */
+ || (!calibrating && ntasks_end < ntasks_best_end)
/* Not calibrating, take better worker */
|| (!calibrating &&
isnan(local_task_length[worker][nimpl])) /* Not calibrating but this worker
is being calibrated */
|| (calibrating &&
isnan(local_task_length[worker][nimpl]) && ntasks_end < ntasks_best_end) /*
Calibrating, compete this worker with other non-calibrated */
ntasks_best_end = ntasks_end;
ntasks_best = worker;
- best_impl = nimpl;
+ nimpl_best = nimpl;
if (isnan(local_task_length[worker][nimpl]))
@@ -474,13 +485,13 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
calibrating = 1;
_STARPU_IS_ZERO(local_task_length[worker][nimpl]))
/* there is no prediction available for that
task
- * with that arch yet, so switch to a greedy
strategy */
+ * with that arch (yet or at all), so switch
to a greedy strategy */
unknown = 1;
if (unknown)
- continue;
+ continue;
exp_end[worker][nimpl] = fifo->exp_start +
fifo->exp_len + local_task_length[worker][nimpl];
@@ -488,21 +499,57 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
/* a better solution was found */
best_exp_end = exp_end[worker][nimpl];
- local_power[worker][nimpl] =
starpu_task_expected_power(task, perf_arch, nimpl);
if (isnan(local_power[worker][nimpl]))
local_power[worker][nimpl] = 0.;
- if (unknown)
- forced_best = ntasks_best;
+ *forced_worker = unknown?ntasks_best:-1;
+ *forced_impl = unknown?nimpl_best:-1;
+ *best_exp_endp = best_exp_end;
+ *max_exp_endp = max_exp_end;
+static int _dmda_push_task(struct starpu_task *task, unsigned prio)
+ /* find the queue */
+ unsigned worker;
+ int best = -1;
+ int selected_impl = 0;
+ double model_best = 0.0;
+ /* this flag is set if the corresponding worker is selected because
+ there is no performance prediction available yet */
+ int forced_best = -1;
+ int forced_impl = -1;
+ double local_task_length[nworkers][STARPU_MAXIMPLEMENTATIONS];
+ double local_data_penalty[nworkers][STARPU_MAXIMPLEMENTATIONS];
+ double local_power[nworkers][STARPU_MAXIMPLEMENTATIONS];
+ double exp_end[nworkers][STARPU_MAXIMPLEMENTATIONS];
+ double max_exp_end = 0.0;
+ double best_exp_end;
+ double fitness[nworkers][STARPU_MAXIMPLEMENTATIONS];
+ compute_all_performance_predictions(task,
+ local_task_length,
+ exp_end,
+ &max_exp_end,
+ &best_exp_end,
+ local_data_penalty,
+ local_power,
+ &forced_best,
+ &forced_impl);
double best_fitness = -1;
+ unsigned nimpl;
if (forced_best == -1)
@@ -531,7 +578,7 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
/* we found a better solution */
best_fitness = fitness[worker][nimpl];
best = worker;
+ selected_impl = nimpl;
// _STARPU_DEBUG("best
fitness (worker %d) %e = alpha*(%e) + beta(%e) +gamma(%e)\n", worker,
best_fitness, exp_end[worker][nimpl] - best_exp_end,
local_data_penalty[worker][nimpl], local_power[worker][nimpl]);
@@ -551,13 +598,13 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
else
- model_best = local_task_length[best][best_impl];
+ model_best = local_task_length[best][selected_impl];
//penality_best = local_data_penalty[best][best_impl];
//_STARPU_DEBUG("Scheduler dmda: kernel (%u)\n", best_impl);
- _starpu_get_job_associated_to_task(task)->nimpl = best_impl;
+ _starpu_get_job_associated_to_task(task)->nimpl = selected_impl;
/* we should now have the best worker in variable "best" */
1.7.9
- [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 2/7] _starpu_fifo_push_task(): Fix "TODO: if prio, put at back"., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 3/7] Heft: use a scheduler-specific fifo rather than pushing tasks directly to the workers' local tasks., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 4/7] heft.c: Remove the "bundle" parameter from compute_all_performance_predictions()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 5/7] src/sched_policies/deque_modeling_policy_data_aware.c: add a compute_all_performance_predictions() function., Cyril Roelandt, 16/10/2012
- [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 6/7] Reindent _dmda_push_task()., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 7/7] Handle bundles in deque_modeling_policy_data_aware.c., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 7/7] Handle bundles in deque_modeling_policy_data_aware.c., Samuel Thibault, 19/10/2012
- [Starpu-devel] [PATCH 1/7] src/sched_policies/heft.c: use an array of _starpu_fifo_taskq* rather than multiple global variables., Cyril Roelandt, 16/10/2012
- Re: [Starpu-devel] [PATCH 0/7][Review needed] A first step towards the factorization of heft and dm*., Samuel Thibault, 19/10/2012
