Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [PATCH 1/7] src/sched_policies/heft.c: use an array of _starpu_fifo_taskq* rather than multiple global variables.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [PATCH 1/7] src/sched_policies/heft.c: use an array of _starpu_fifo_taskq* rather than multiple global variables.
  • Date: Tue, 16 Oct 2012 23:45:04 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
This way, we get rid of 4 global variables (exp_start, exp_len, exp_end and
ntasks), while adding a new one (queue_array). The whole thing is a bit easier
to read.
trunk/src/sched_policies/heft.c | 82 +++++++++++++++++++++-----------------
1 files changed, 45 insertions(+), 37 deletions(-)
diff --git a/trunk/src/sched_policies/heft.c b/trunk/src/sched_policies/heft.c
index 7232e31..6a5a2c9 100644
--- a/trunk/src/sched_policies/heft.c
+++ b/trunk/src/sched_policies/heft.c
@@ -28,6 +28,7 @@
#include <starpu_top.h>
#include <core/jobs.h>
#include <top/starpu_top_core.h>
+#include <sched_policies/fifo_queues.h>
#ifndef DBL_MIN
#define DBL_MIN __DBL_MIN__
@@ -38,6 +39,7 @@
#endif
static unsigned nworkers;
+static struct _starpu_fifo_taskq *queue_array[STARPU_NMAXWORKERS];
static pthread_cond_t sched_cond[STARPU_NMAXWORKERS];
static pthread_mutex_t sched_mutex[STARPU_NMAXWORKERS];
@@ -47,11 +49,6 @@ static double beta = _STARPU_DEFAULT_BETA;
static double _gamma = _STARPU_DEFAULT_GAMMA;
static double idle_power = 0.0;
-static double exp_start[STARPU_NMAXWORKERS]; /* of the first queued task */
-static double exp_end[STARPU_NMAXWORKERS]; /* of the set of queued tasks */
-static double exp_len[STARPU_NMAXWORKERS]; /* of the last queued task */
-static double ntasks[STARPU_NMAXWORKERS];
const float alpha_minimum=0;
const float alpha_maximum=10.0;
const float beta_minimum=0;
@@ -97,10 +94,13 @@ static void heft_init(struct starpu_machine_topology
*topology,
unsigned workerid;
for (workerid = 0; workerid < nworkers; workerid++)
- exp_start[workerid] = starpu_timing_now();
- exp_len[workerid] = 0.0;
- exp_end[workerid] = exp_start[workerid];
- ntasks[workerid] = 0;
+ queue_array[workerid] = _starpu_create_fifo();
+ struct _starpu_fifo_taskq *fifo = queue_array[workerid];
+ fifo->exp_start = starpu_timing_now();
+ fifo->exp_len = 0.0;
+ fifo->exp_end = fifo->exp_start;
+ fifo->ntasks = 0;
_STARPU_PTHREAD_MUTEX_INIT(&sched_mutex[workerid], NULL);
_STARPU_PTHREAD_COND_INIT(&sched_cond[workerid], NULL);
@@ -115,21 +115,24 @@ static void heft_init(struct starpu_machine_topology
*topology,
static void heft_pre_exec_hook(struct starpu_task *task)
int workerid = starpu_worker_get_id();
double model = task->predicted;
double transfer_model = task->predicted_transfer;
/* Once the task is executing, we can update the predicted amount
* of work. */
_STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[workerid]);
- exp_len[workerid] -= model + transfer_model;
- exp_start[workerid] = starpu_timing_now() + model;
- exp_end[workerid] = exp_start[workerid] + exp_len[workerid];
- ntasks[workerid]--;
+ fifo->exp_len-= model + transfer_model;
+ fifo->exp_start = starpu_timing_now() + model;
+ fifo->exp_end= fifo->exp_start + fifo->exp_len;
+ fifo->ntasks--;
_STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[workerid]);
static void heft_push_task_notify(struct starpu_task *task, int workerid)
/* Compute the expected penality */
enum starpu_perf_archtype perf_arch =
starpu_worker_get_perf_archtype(workerid);
unsigned memory_node = starpu_worker_get_memory_node(workerid);
@@ -143,21 +146,21 @@ static void heft_push_task_notify(struct starpu_task
/* Sometimes workers didn't take the tasks as early as we expected */
- exp_start[workerid] = STARPU_MAX(exp_start[workerid],
starpu_timing_now());
+ fifo->exp_start = STARPU_MAX(fifo->exp_start, starpu_timing_now());
+ fifo->exp_end = fifo->exp_start + fifo->exp_len;
/* If there is no prediction available, we consider the task has a
null length */
if (!isnan(predicted))
task->predicted = predicted;
- exp_end[workerid] += predicted;
- exp_len[workerid] += predicted;
+ fifo->exp_end += predicted;
+ fifo->exp_len += predicted;
null length */
if (!isnan(predicted_transfer))
- if (starpu_timing_now() + predicted_transfer <
exp_end[workerid])
+ if (starpu_timing_now() + predicted_transfer < fifo->exp_end)
/* We may hope that the transfer will be finished by
* the start of the task. */
@@ -167,33 +170,35 @@ static void heft_push_task_notify(struct starpu_task
/* The transfer will not be finished by then, take the
* remainder into account */
- predicted_transfer = (starpu_timing_now() +
predicted_transfer) - exp_end[workerid];
+ predicted_transfer = (starpu_timing_now() +
predicted_transfer) - fifo->exp_end;
task->predicted_transfer = predicted_transfer;
- exp_end[workerid] += predicted_transfer;
- exp_len[workerid] += predicted_transfer;
+ fifo->exp_end += predicted_transfer;
+ fifo->exp_len += predicted_transfer;
- ntasks[workerid]++;
+ fifo->ntasks++;
static int push_task_on_best_worker(struct starpu_task *task, int
best_workerid, double predicted, double predicted_transfer, int prio)
+ struct _starpu_fifo_taskq *fifo = queue_array[best_workerid];
/* make sure someone coule execute that task ! */
STARPU_ASSERT(best_workerid != -1);
_STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[best_workerid]);
- exp_start[best_workerid] = STARPU_MAX(exp_start[best_workerid],
- exp_end[best_workerid] = exp_start[best_workerid] +
exp_len[best_workerid];
- exp_end[best_workerid] += predicted;
- exp_len[best_workerid] += predicted;
- if (starpu_timing_now() + predicted_transfer < exp_end[best_workerid])
@@ -203,12 +208,12 @@ static int push_task_on_best_worker(struct starpu_task
*task, int best_workerid,
predicted_transfer) - exp_end[best_workerid];
- exp_end[best_workerid] += predicted_transfer;
- exp_len[best_workerid] += predicted_transfer;
- ntasks[best_workerid]++;
+ fifo->ntasks++;
_STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[best_workerid]);
@@ -216,8 +221,8 @@ static int push_task_on_best_worker(struct starpu_task
if (_starpu_top_status_get())
_starpu_top_task_prevision(task, best_workerid,
- (unsigned long
long)(exp_end[best_workerid]-predicted)/1000,
- (unsigned long
long)exp_end[best_workerid]/1000);
+ (unsigned long
long)(fifo->exp_end-predicted)/1000,
+ (unsigned long
long)fifo->exp_end/1000);
if (starpu_get_prefetch_flag())
@@ -257,6 +262,8 @@ static void compute_all_performance_predictions(struct
starpu_task *task,
for (worker = 0; worker < nworkers; worker++)
+ struct _starpu_fifo_taskq *fifo = queue_array[worker];
for (nimpl = 0; nimpl < STARPU_MAXIMPLEMENTATIONS; nimpl++)
if (!starpu_worker_can_execute_task(worker, task,
nimpl))
@@ -267,8 +274,8 @@ static void compute_all_performance_predictions(struct
starpu_task *task,
as we expected */
_STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[worker]);
- exp_start[worker] = STARPU_MAX(exp_start[worker],
- exp_end[worker][nimpl] = exp_start[worker] +
exp_len[worker];
+ exp_end[worker][nimpl] = fifo->exp_start +
fifo->exp_len;
if (exp_end[worker][nimpl] > max_exp_end)
max_exp_end = exp_end[worker][nimpl];
_STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[worker]);
@@ -297,7 +304,7 @@ static void compute_all_performance_predictions(struct
starpu_task *task,
- double ntasks_end = ntasks[worker] /
starpu_worker_get_relative_speedup(perf_arch);
+ double ntasks_end = fifo->ntasks /
if (ntasks_best == -1
|| (!calibrating && ntasks_end < ntasks_best_end)
/* Not calibrating, take better worker */
@@ -325,7 +332,7 @@ static void compute_all_performance_predictions(struct
starpu_task *task,
if (unknown)
continue;
exp_len[worker] + local_task_length[worker][nimpl];
fifo->exp_len + local_task_length[worker][nimpl];
if (exp_end[worker][nimpl] < best_exp_end)
@@ -526,6 +533,7 @@ static void heft_deinit(__attribute__ ((unused)) struct
unsigned workerid;
+ _starpu_destroy_fifo(queue_array[workerid]);
_STARPU_PTHREAD_MUTEX_DESTROY(&sched_mutex[workerid]);
_STARPU_PTHREAD_COND_DESTROY(&sched_cond[workerid]);
1.7.9
Haut de le page
