Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [PATCH 3/5] dmda*: take into account the data transfer time.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [PATCH 3/5] dmda*: take into account the data transfer time.
  • Date: Wed, 28 Nov 2012 00:35:10 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
push_task_on_best_worker now has one more parameter: the expected data
transfer time.
.../deque_modeling_policy_data_aware.c | 52
1 file changed, 43 insertions(+), 9 deletions(-)
diff --git a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
index 92dc111..87a5edd 100644
--- a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
+++ b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
@@ -216,21 +216,45 @@ static struct starpu_task *dmda_pop_every_task(void)
-static int push_task_on_best_worker(struct starpu_task *task, int
best_workerid, double predicted, int prio)
+static int push_task_on_best_worker(struct starpu_task *task, int
best_workerid,
+ double predicted, double
predicted_transfer,
+ int prio)
/* make sure someone coule execute that task ! */
STARPU_ASSERT(best_workerid != -1);
- struct _starpu_fifo_taskq *fifo;
- fifo = queue_array[best_workerid];
+ struct _starpu_fifo_taskq *fifo = queue_array[best_workerid];
+ _STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[best_workerid]);
+ /* Sometimes workers didn't take the tasks as early as we expected */
+ fifo->exp_start = STARPU_MAX(fifo->exp_start, starpu_timing_now());
+ fifo->exp_end = fifo->exp_start + fifo->exp_len;
fifo->exp_end += predicted;
fifo->exp_len += predicted;
- task->predicted = predicted;
+ if (starpu_timing_now() + predicted_transfer < fifo->exp_end)
+ /* We may hope that the transfer will be finished by
+ * the start of the task. */
+ predicted_transfer = 0;
+ else
+ /* The transfer will not be finished by then, take the
+ * remainder into account */
+ predicted_transfer += starpu_timing_now();
+ predicted_transfer -= fifo->exp_end;
+ fifo->exp_end += predicted_transfer;
+ fifo->exp_len += predicted_transfer;
- /* TODO predicted_transfer */
+ _STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[best_workerid]);
+ task->predicted = predicted;
+ task->predicted_transfer = predicted_transfer;
if (starpu_get_prefetch_flag())
@@ -262,6 +286,7 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
double best_exp_end = 0.0;
double model_best = 0.0;
+ double transfer_model_best = 0.0;
int ntasks_best = -1;
double ntasks_best_end = 0.0;
@@ -275,6 +300,7 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
for (worker = 0; worker < nworkers; worker++)
+ unsigned memory_node = starpu_worker_get_memory_node(worker);
for (nimpl = 0; nimpl < STARPU_MAXIMPLEMENTATIONS; nimpl++)
double exp_end;
@@ -293,6 +319,7 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
enum starpu_perf_archtype perf_arch =
starpu_worker_get_perf_archtype(worker);
double local_length =
starpu_task_expected_length(task, perf_arch, nimpl);
+ double local_penalty =
starpu_task_expected_data_transfer_time(memory_node, task);
double ntasks_end = fifo->ntasks /
starpu_worker_get_relative_speedup(perf_arch);
//_STARPU_DEBUG("Scheduler dm: task length (%lf)
worker (%u) kernel (%u) \n", local_length,worker,nimpl);
@@ -330,6 +357,7 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
best_exp_end = exp_end;
best = worker;
model_best = local_length;
+ transfer_model_best = local_penalty;
best_impl = nimpl;
@@ -339,6 +367,7 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
best = ntasks_best;
model_best = 0.0;
+ transfer_model_best = 0.0;
//_STARPU_DEBUG("Scheduler dm: kernel (%u)\n", best_impl);
@@ -346,7 +375,8 @@ static int _dm_push_task(struct starpu_task *task,
unsigned prio)
_starpu_get_job_associated_to_task(task)->nimpl = best_impl;
/* we should now have the best worker in variable "best" */
- return push_task_on_best_worker(task, best, model_best, prio);
+ return push_task_on_best_worker(task, best,
+ model_best, transfer_model_best,
prio);
static void compute_all_performance_predictions(struct starpu_task *task,
@@ -472,6 +502,7 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
int best = -1;
int selected_impl = 0;
/* this flag is set if the corresponding worker is selected because
there is no performance prediction available yet */
@@ -546,17 +577,19 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
* so we force this measurement */
best = forced_best;
model_best = 0.0;
- //penality_best = 0.0;
else if (task->bundle)
starpu_worker_get_perf_archtype(best);
+ unsigned memory_node = starpu_worker_get_memory_node(best);
model_best = starpu_task_expected_length(task, perf_arch,
selected_impl);
else
model_best = local_task_length[best][selected_impl];
- //penality_best = local_data_penalty[best][best_impl];
+ transfer_model_best = local_data_penalty[best][selected_impl];
if (task->bundle)
@@ -567,7 +600,8 @@ static int _dmda_push_task(struct starpu_task *task,
unsigned prio)
_starpu_get_job_associated_to_task(task)->nimpl = selected_impl;
prio);
static int dmda_push_sorted_task(struct starpu_task *task)
1.7.10.4
Haut de le page
