Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] [PATCH 5/5] Remove heft.
- Date: Wed, 28 Nov 2012 00:35:12 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Users should now use dmda. This commit removes the heft scheduler, updates the
documentation and gets rid of heft in the tests.
trunk/doc/chapters/advanced-examples.texi | 10 +-
trunk/doc/chapters/benchmarks.texi | 2 +-
trunk/doc/chapters/configuration.texi | 2 +-
trunk/doc/chapters/perf-feedback.texi | 4 +-
trunk/doc/chapters/perf-optimization.texi | 3 +-
trunk/gcc-plugin/examples/cholesky/cholesky.c | 2 +-
trunk/src/Makefile.am | 1 -
trunk/src/core/sched_policy.c | 7 +-
trunk/src/core/sched_policy.h | 1 -
trunk/src/sched_policies/eager_central_policy.c | 2 +-
trunk/src/sched_policies/heft.c | 523
trunk/tests/sched_policies/data_locality.c | 4 +-
trunk/tests/sched_policies/execute_all_tasks.c | 2 -
trunk/tests/sched_policies/simple_cpu_gpu_sched.c | 8 +-
trunk/tests/sched_policies/simple_deps.c | 2 -
15 files changed, 23 insertions(+), 550 deletions(-)
delete mode 100644 trunk/src/sched_policies/heft.c
diff --git a/trunk/doc/chapters/advanced-examples.texi
b/trunk/doc/chapters/advanced-examples.texi
index 78676c0..8f4af46 100644
--- a/trunk/doc/chapters/advanced-examples.texi
+++ b/trunk/doc/chapters/advanced-examples.texi
@@ -63,8 +63,8 @@ struct starpu_codelet cl = @{
@end smallexample
@end cartouche
-Schedulers which are multi-implementation aware (only @code{dmda},
@code{heft}
-and @code{pheft} for now) will use the performance models of all the
+Schedulers which are multi-implementation aware (only @code{dmda} and
+@code{pheft} for now) will use the performance models of all the
implementations it was given, and pick the one that seems to be the fastest.
@node Enabling implementation according to capabilities
@@ -334,7 +334,7 @@ the @code{starpu_perfmodel_plot} (@pxref{Performance
model calibration}). The
models are indexed by machine name. To
share the models between machines (e.g. for a homogeneous cluster), use
@code{export STARPU_HOSTNAME=some_global_name}. Measurements are only done
-when using a task scheduler which makes use of it, such as @code{heft} or
+when using a task scheduler which makes use of it, such as
@code{dmda}. Measurements can also be provided explicitly by the
application, by
using the @code{starpu_perfmodel_update_history} function.
@@ -389,7 +389,7 @@ inputs. The application can also provide the measurements
explictly by using
tools can be used to observe how much the performance model is calibrated
(@pxref{Performance model calibration}); when
their output look good, @code{STARPU_CALIBRATE} can be reset to @code{0} to
let
StarPU use the resulting performance model without recording new measures,
and
-@code{STARPU_SCHED} can be set to @code{heft} to benefit from the
performance models. If
+@code{STARPU_SCHED} can be set to @code{dmda} to benefit from the
the data input sizes vary a lot, it is really important to set
@code{STARPU_CALIBRATE} to @code{0}, otherwise StarPU will continue adding
the
measures, and result with a very big performance model, which will take time
a
@@ -973,7 +973,7 @@ It may be interesting to represent the same piece of data
using two different
data structures: one that would only be used on CPUs, and one that would only
be used on GPUs. This can be done by using the multiformat interface. StarPU
will be able to convert data from one data structure to the other when
needed.
-Note that the heft scheduler is the only one optimized for this interface.
The
+Note that the dmda scheduler is the only one optimized for this interface.
The
user must provide StarPU with conversion codelets:
@cartouche
diff --git a/trunk/doc/chapters/benchmarks.texi
b/trunk/doc/chapters/benchmarks.texi
index 1e70081..c2a8211 100644
--- a/trunk/doc/chapters/benchmarks.texi
+++ b/trunk/doc/chapters/benchmarks.texi
@@ -14,7 +14,7 @@
Some interesting benchmarks are installed among examples in
/usr/lib/starpu/examples . Make sure to try various schedulers, for instance
-STARPU_SCHED=heft
+STARPU_SCHED=dmda
@node Task size overhead
@section Task size overhead
diff --git a/trunk/doc/chapters/configuration.texi
b/trunk/doc/chapters/configuration.texi
index 1d684a6..ad02f30 100644
--- a/trunk/doc/chapters/configuration.texi
+++ b/trunk/doc/chapters/configuration.texi
@@ -447,7 +447,7 @@ the execution. If it is set to 2, the previous values are
dropped to restart
calibration from scratch. Setting this variable to 0 disable calibration,
this
is the default behaviour.
-Note: this currently only applies to @code{dm}, @code{dmda} and @code{heft}
scheduling policies.
+Note: this currently only applies to @code{dm} and @code{dmda} scheduling
policies.
@end defvr
@defvr {Environment variable} STARPU_BUS_CALIBRATE
diff --git a/trunk/doc/chapters/perf-feedback.texi
b/trunk/doc/chapters/perf-feedback.texi
index aff147d..2b3f5d4 100644
--- a/trunk/doc/chapters/perf-feedback.texi
+++ b/trunk/doc/chapters/perf-feedback.texi
@@ -221,13 +221,13 @@ start the application itself (possibly on a remote
machine). The SSH checkbox
should be checked, and a command line provided, e.g.:
@example
-ssh myserver STARPU_SCHED=heft ./application
+ssh myserver STARPU_SCHED=dmda ./application
@end example
If port 2011 of the remote machine can not be accessed directly, an ssh port
bridge should be added:
@example
-ssh -L 2011:localhost:2011 myserver STARPU_SCHED=heft ./application
+ssh -L 2011:localhost:2011 myserver STARPU_SCHED=dmda ./application
@end example
and "localhost" should be used as IP Address to connect to.
diff --git a/trunk/doc/chapters/perf-optimization.texi
b/trunk/doc/chapters/perf-optimization.texi
index 2c5c420..31873ae 100644
--- a/trunk/doc/chapters/perf-optimization.texi
+++ b/trunk/doc/chapters/perf-optimization.texi
@@ -186,7 +186,8 @@ buffers.
The @b{dmdas} (deque model data aware sorted) scheduler is similar to dmda,
it
also supports arbitrary priority values.
-The @b{heft} (heterogeneous earliest finish time) scheduler is similar to
dmda, it also supports task bundles.
+The @b{heft} (heterogeneous earliest finish time) scheduler is deprecated. It
+is now just an alias for @b{dmda}.
The @b{pheft} (parallel HEFT) scheduler is similar to heft, it also supports
parallel tasks (still experimental).
diff --git a/trunk/gcc-plugin/examples/cholesky/cholesky.c
b/trunk/gcc-plugin/examples/cholesky/cholesky.c
index cbf4991..7049110 100644
--- a/trunk/gcc-plugin/examples/cholesky/cholesky.c
+++ b/trunk/gcc-plugin/examples/cholesky/cholesky.c
@@ -107,7 +107,7 @@ int main(int argc, char **argv)
#endif
// struct starpu_conf conf;
// starpu_conf_init(&conf);
-// conf.sched_policy_name = "heft";
+// conf.sched_policy_name = "dmda";
// conf.calibrate = 1;
#pragma starpu initialize
diff --git a/trunk/src/Makefile.am b/trunk/src/Makefile.am
index da9c62b..0acee57 100644
--- a/trunk/src/Makefile.am
+++ b/trunk/src/Makefile.am
@@ -156,7 +156,6 @@ libstarpu_@STARPU_EFFECTIVE_VERSION@_la_SOURCES =
sched_policies/eager_central_priority_policy.c \
sched_policies/work_stealing_policy.c \
sched_policies/deque_modeling_policy_data_aware.c \
- sched_policies/heft.c \
sched_policies/random_policy.c \
sched_policies/stack_queues.c \
sched_policies/deque_queues.c \
diff --git a/trunk/src/core/sched_policy.c b/trunk/src/core/sched_policy.c
index 252dbf9..a5e2339 100644
--- a/trunk/src/core/sched_policy.c
+++ b/trunk/src/core/sched_policy.c
@@ -40,7 +40,6 @@ static struct starpu_sched_policy *predefined_policies[] =
&_starpu_sched_prio_policy,
&_starpu_sched_dm_policy,
&_starpu_sched_dmda_policy,
- &_starpu_sched_heft_policy,
&_starpu_sched_dmda_ready_policy,
&_starpu_sched_dmda_sorted_policy,
&_starpu_sched_random_policy,
@@ -81,6 +80,12 @@ static struct starpu_sched_policy
*find_sched_policy_from_name(const char *polic
if (!policy_name)
return NULL;
+ if (strncmp(policy_name, "heft", 5) == 0)
+ _STARPU_DISP("Warning: heft is now called \"dmda\".\n");
+ return &_starpu_sched_dmda_policy;
unsigned i;
for (i = 0; i <
sizeof(predefined_policies)/sizeof(predefined_policies[0]); i++)
diff --git a/trunk/src/core/sched_policy.h b/trunk/src/core/sched_policy.h
index a3ebbee..e9cc31b 100644
--- a/trunk/src/core/sched_policy.h
+++ b/trunk/src/core/sched_policy.h
@@ -55,7 +55,6 @@ extern struct starpu_sched_policy
_starpu_sched_dmda_sorted_policy;
extern struct starpu_sched_policy _starpu_sched_eager_policy;
extern struct starpu_sched_policy _starpu_sched_parallel_heft_policy;
extern struct starpu_sched_policy _starpu_sched_pgreedy_policy;
-extern struct starpu_sched_policy _starpu_sched_heft_policy;
#endif // __SCHED_POLICY_H__
diff --git a/trunk/src/sched_policies/eager_central_policy.c
b/trunk/src/sched_policies/eager_central_policy.c
index a1448b8..5e33648 100644
--- a/trunk/src/sched_policies/eager_central_policy.c
+++ b/trunk/src/sched_policies/eager_central_policy.c
@@ -32,7 +32,7 @@ static _starpu_pthread_mutex_t sched_mutex;
static void initialize_eager_center_policy(struct starpu_machine_topology
*topology,
__attribute__ ((unused)) struct starpu_sched_policy
*_policy)
- _STARPU_DISP("Warning: you are running the default eager scheduler,
which is not very smart. Make sure to read the StarPU documentation about
adding performance models in order to be able to use the heft or dmda
schedulers instead.\n");
+ _STARPU_DISP("Warning: you are running the default eager scheduler,
adding performance models in order to be able to use the dmda scheduler
instead.\n");
/* there is only a single queue in that trivial design */
fifo = _starpu_create_fifo();
diff --git a/trunk/src/sched_policies/heft.c b/trunk/src/sched_policies/heft.c
deleted file mode 100644
index 248d77b..0000000
--- a/trunk/src/sched_policies/heft.c
+++ /dev/null
@@ -1,523 +0,0 @@
-/* StarPU --- Runtime system for heterogeneous multicore architectures.
- * Copyright (C) 2010, 2011-2012 Université de Bordeaux 1
- * Copyright (C) 2010, 2011, 2012 Centre National de la Recherche
Scientifique
- * Copyright (C) 2011 Télécom-SudParis
- * StarPU is free software; you can redistribute it and/or modify
- * it under the terms of the GNU Lesser General Public License as published
by
- * the Free Software Foundation; either version 2.1 of the License, or (at
- * your option) any later version.
- * StarPU is distributed in the hope that it will be useful, but
- * WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- * See the GNU Lesser General Public License in COPYING.LGPL for more
details.
-/* Distributed queues using performance modeling to assign tasks */
-#include <float.h>
-#include <core/perfmodel/perfmodel.h>
-#include <core/task_bundle.h>
-#include <core/workers.h>
-#include <starpu_parameters.h>
-#include <starpu_task_bundle.h>
-#include <starpu_top.h>
-#include <core/jobs.h>
-#include <top/starpu_top_core.h>
-#include <sched_policies/fifo_queues.h>
-#include <core/debug.h>
-#ifndef DBL_MIN
-#define DBL_MIN __DBL_MIN__
-#endif
-#ifndef DBL_MAX
-#define DBL_MAX __DBL_MAX__
-#endif
-static unsigned nworkers;
-static struct _starpu_fifo_taskq *queue_array[STARPU_NMAXWORKERS];
-static _starpu_pthread_cond_t sched_cond[STARPU_NMAXWORKERS];
-static _starpu_pthread_mutex_t sched_mutex[STARPU_NMAXWORKERS];
-static double alpha = _STARPU_DEFAULT_ALPHA;
-static double beta = _STARPU_DEFAULT_BETA;
-static double _gamma = _STARPU_DEFAULT_GAMMA;
-static double idle_power = 0.0;
-const float alpha_minimum=0;
-const float alpha_maximum=10.0;
-const float beta_minimum=0;
-const float beta_maximum=10.0;
-const float gamma_minimum=0;
-const float gamma_maximum=10000.0;
-const float idle_power_minimum=0;
-const float idle_power_maximum=10000.0;
-static void param_modified(struct starpu_top_param* d)
- //just to show parameter modification
- fprintf(stderr,"%s has been modified :
alpha=%f|beta=%f|gamma=%f|idle_power=%f !\n",
- d->name, alpha,beta,_gamma,idle_power);
-static void heft_init(struct starpu_machine_topology *topology,
- __attribute__ ((unused)) struct starpu_sched_policy *_policy)
- nworkers = topology->nworkers;
- const char *strval_alpha = getenv("STARPU_SCHED_ALPHA");
- if (strval_alpha)
- alpha = atof(strval_alpha);
- const char *strval_beta = getenv("STARPU_SCHED_BETA");
- if (strval_beta)
- beta = atof(strval_beta);
- const char *strval_gamma = getenv("STARPU_SCHED_GAMMA");
- if (strval_gamma)
- _gamma = atof(strval_gamma);
- const char *strval_idle_power = getenv("STARPU_IDLE_POWER");
- if (strval_idle_power)
- idle_power = atof(strval_idle_power);
- starpu_top_register_parameter_float("HEFT_ALPHA", &alpha,
alpha_minimum,alpha_maximum,param_modified);
- starpu_top_register_parameter_float("HEFT_BETA", &beta,
beta_minimum,beta_maximum,param_modified);
- starpu_top_register_parameter_float("HEFT_GAMMA", &_gamma,
gamma_minimum,gamma_maximum,param_modified);
- starpu_top_register_parameter_float("HEFT_IDLE_POWER", &idle_power,
idle_power_minimum,idle_power_maximum,param_modified);
- unsigned workerid;
- for (workerid = 0; workerid < nworkers; workerid++)
- queue_array[workerid] = _starpu_create_fifo();
- _STARPU_PTHREAD_MUTEX_INIT(&sched_mutex[workerid], NULL);
- _STARPU_PTHREAD_COND_INIT(&sched_cond[workerid], NULL);
- starpu_worker_set_sched_condition(workerid,
&sched_cond[workerid], &sched_mutex[workerid]);
-/* heft_pre_exec_hook is called right after the data transfer is done and
right before
- * the computation to begin, it is useful to update more precisely the value
- * of the expected start, end, length, etc... */
-static void heft_pre_exec_hook(struct starpu_task *task)
- int workerid = starpu_worker_get_id();
- struct _starpu_fifo_taskq *fifo = queue_array[workerid];
- double model = task->predicted;
- double transfer_model = task->predicted_transfer;
- /* Once the task is executing, we can update the predicted amount
- * of work. */
- _STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[workerid]);
- fifo->exp_len-= transfer_model;
- fifo->exp_start = starpu_timing_now() + model;
- fifo->exp_end= fifo->exp_start + fifo->exp_len;
- _STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[workerid]);
-static void heft_push_task_notify(struct starpu_task *task, int workerid)
- /* Compute the expected penality */
- enum starpu_perf_archtype perf_arch =
starpu_worker_get_perf_archtype(workerid);
- unsigned memory_node = starpu_worker_get_memory_node(workerid);
- double predicted = starpu_task_expected_length(task, perf_arch,
- _starpu_get_job_associated_to_task(task)->nimpl);
- double predicted_transfer =
starpu_task_expected_data_transfer_time(memory_node, task);
- /* Update the predictions */
- /* Sometimes workers didn't take the tasks as early as we expected */
- fifo->exp_start = STARPU_MAX(fifo->exp_start, starpu_timing_now());
- fifo->exp_end = fifo->exp_start + fifo->exp_len;
- /* If there is no prediction available, we consider the task has a
null length */
- if (!isnan(predicted))
- task->predicted = predicted;
- fifo->exp_end += predicted;
- fifo->exp_len += predicted;
null length */
- if (!isnan(predicted_transfer))
- if (starpu_timing_now() + predicted_transfer < fifo->exp_end)
- /* We may hope that the transfer will be finished by
- * the start of the task. */
- predicted_transfer = 0;
- else
- /* The transfer will not be finished by then, take the
- * remainder into account */
- predicted_transfer = (starpu_timing_now() +
predicted_transfer) - fifo->exp_end;
- task->predicted_transfer = predicted_transfer;
- fifo->exp_end += predicted_transfer;
- fifo->exp_len += predicted_transfer;
- fifo->ntasks++;
-static int push_task_on_best_worker(struct starpu_task *task, int
best_workerid, double predicted, double predicted_transfer)
- struct _starpu_fifo_taskq *fifo = queue_array[best_workerid];
- /* make sure someone coule execute that task ! */
- STARPU_ASSERT(best_workerid != -1);
- _STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[best_workerid]);
- else
- _STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[best_workerid]);
- if (_starpu_top_status_get())
- _starpu_top_task_prevision(task, best_workerid,
- (unsigned long
long)(fifo->exp_end-predicted)/1000,
- (unsigned long
long)fifo->exp_end/1000);
- if (starpu_get_prefetch_flag())
starpu_worker_get_memory_node(best_workerid);
- starpu_prefetch_task_input_on_node(task, memory_node);
-#ifdef HAVE_AYUDAME_H
- if (AYU_event) {
- int id = best_workerid;
- AYU_event(AYU_ADDTASKTOQUEUE,
_starpu_get_job_associated_to_task(task)->job_id, &id);
-#endif
- return _starpu_fifo_push_task(queue_array[best_workerid],
- &sched_mutex[best_workerid],
- &sched_cond[best_workerid], task);
-/* TODO: Correct the bugs in the scheduling !!! */
-/* TODO: factorize with dmda!! */
-static void compute_all_performance_predictions(struct starpu_task *task,
- double
local_task_length[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
- double
exp_end[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
- double *max_exp_endp,
- double *best_exp_endp,
- double
local_data_penalty[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
- double
local_power[STARPU_NMAXWORKERS][STARPU_MAXIMPLEMENTATIONS],
- int *forced_worker, int *forced_impl)
- int calibrating = 0;
- double max_exp_end = DBL_MIN;
- double best_exp_end = DBL_MAX;
- int ntasks_best = -1;
- int nimpl_best = 0;
- double ntasks_best_end = 0.0;
- /* A priori, we know all estimations */
- int unknown = 0;
- unsigned worker;
- unsigned nimpl;
- starpu_task_bundle_t bundle = task->bundle;
- for (worker = 0; worker < nworkers; worker++)
- struct _starpu_fifo_taskq *fifo = queue_array[worker];
- for (nimpl = 0; nimpl < STARPU_MAXIMPLEMENTATIONS; nimpl++)
- if (!starpu_worker_can_execute_task(worker, task,
nimpl))
- /* no one on that queue may execute this task
- continue;
as we expected */
- _STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[worker]);
- exp_end[worker][nimpl] = fifo->exp_start +
fifo->exp_len;
- _STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[worker]);
- if (exp_end[worker][nimpl] > max_exp_end)
- max_exp_end = exp_end[worker][nimpl];
starpu_worker_get_perf_archtype(worker);
starpu_worker_get_memory_node(worker);
- if (bundle)
- /* TODO : conversion time */
- local_task_length[worker][nimpl] =
starpu_task_bundle_expected_length(bundle, perf_arch, nimpl);
- local_data_penalty[worker][nimpl] =
starpu_task_bundle_expected_data_transfer_time(bundle, memory_node);
- local_power[worker][nimpl] =
starpu_task_bundle_expected_power(bundle, perf_arch,nimpl);
- //_STARPU_DEBUG("Scheduler heft bundle: task
length (%lf) local power (%lf) worker (%u) kernel (%u) \n",
local_task_length[worker],local_power[worker],worker,nimpl);
- else
starpu_task_expected_length(task, perf_arch, nimpl);
starpu_task_expected_power(task, perf_arch,nimpl);
- double conversion_time =
starpu_task_expected_conversion_time(task, perf_arch, nimpl);
- if (conversion_time > 0.0)
- local_task_length[worker][nimpl] +=
conversion_time;
- //_STARPU_DEBUG("Scheduler heft: task length
- double ntasks_end = fifo->ntasks /
starpu_worker_get_relative_speedup(perf_arch);
- if (ntasks_best == -1
- || (!calibrating && ntasks_end < ntasks_best_end)
/* Not calibrating, take better worker */
isnan(local_task_length[worker][nimpl])) /* Not calibrating but this worker
is being calibrated */
- || (calibrating &&
isnan(local_task_length[worker][nimpl]) && ntasks_end < ntasks_best_end) /*
Calibrating, compete this worker with other non-calibrated */
- ntasks_best_end = ntasks_end;
- ntasks_best = worker;
- nimpl_best = nimpl;
- if (isnan(local_task_length[worker][nimpl]))
- /* we are calibrating, we want to speed-up
calibration time
- * so we privilege non-calibrated tasks (but
still
- * greedily distribute them to avoid dumb
schedules) */
- calibrating = 1;
_STARPU_IS_ZERO(local_task_length[worker][nimpl]))
- /* there is no prediction available for that
task
- * with that arch (yet or at all), so switch
to a greedy strategy */
- unknown = 1;
- if (unknown)
- continue;
fifo->exp_len + local_task_length[worker][nimpl];
- if (exp_end[worker][nimpl] < best_exp_end)
- /* a better solution was found */
- best_exp_end = exp_end[worker][nimpl];
- if (isnan(local_power[worker][nimpl]))
- local_power[worker][nimpl] = 0.;
- *forced_worker = unknown?ntasks_best:-1;
- *forced_impl = unknown?nimpl_best:-1;
- *best_exp_endp = best_exp_end;
- *max_exp_endp = max_exp_end;
-static int _heft_push_task(struct starpu_task *task, unsigned prio)
- unsigned worker, nimpl;
- int best = -1;
- int selected_impl= -1;
- /* this flag is set if the corresponding worker is selected because
- there is no performance prediction available yet */
- int forced_worker;
- int forced_impl;
- double local_task_length[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double local_data_penalty[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double local_power[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double exp_end[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double max_exp_end = 0.0;
- double best_exp_end;
- * Compute the expected end of the task on the various workers,
- * and detect if there is some calibration that needs to be done.
- compute_all_performance_predictions(task, local_task_length, exp_end,
- &max_exp_end, &best_exp_end,
- local_data_penalty,
- local_power, &forced_worker,
&forced_impl);
- /* If there is no prediction available for that task with that arch we
- * want to speed-up calibration time so we force this measurement */
- if (forced_worker != -1)
- _starpu_get_job_associated_to_task(task)->nimpl = forced_impl;
- if (task->bundle)
- starpu_task_bundle_remove(task->bundle, task);
- return push_task_on_best_worker(task, forced_worker, 0.0,
0.0);
- * Determine which worker optimizes the fitness metric which is a
- * trade-off between load-balacing, data locality, and energy
- * consumption.
- double fitness[nworkers][STARPU_MAXIMPLEMENTATIONS];
- double best_fitness = -1;
nimpl))
- continue;
- fitness[worker][nimpl] =
alpha*(exp_end[worker][nimpl] - best_exp_end)
beta*(local_data_penalty[worker][nimpl])
_gamma*(local_power[worker][nimpl]);
- /* This placement will make the computation
- * longer, take into account the idle
- * consumption of other cpus */
- fitness[worker][nimpl] += _gamma * idle_power
* (exp_end[worker][nimpl] - max_exp_end) / 1000000.0;
- if (best == -1 || fitness[worker][nimpl] <
best_fitness)
- /* we found a better solution */
- best_fitness = fitness[worker][nimpl];
- best = worker;
- selected_impl = nimpl;
- /* By now, we must have found a solution */
- STARPU_ASSERT(best != -1);
- /* we should now have the best worker in variable "best" */
- double model_best, transfer_model_best;
- if (task->bundle)
- /* If we have a task bundle, we have computed the expected
- * length for the entire bundle, but not for the task alone.
starpu_worker_get_perf_archtype(best);
- unsigned memory_node = starpu_worker_get_memory_node(best);
- model_best = starpu_task_expected_length(task, perf_arch,
selected_impl);
- transfer_model_best =
- /* Remove the task from the bundle since we have made a
- * decision for it, and that other tasks should not consider
it
- * anymore. */
- else
- model_best = local_task_length[best][selected_impl];
- transfer_model_best = local_data_penalty[best][selected_impl];
- _starpu_get_job_associated_to_task(task)->nimpl = selected_impl;
- return push_task_on_best_worker(task, best, model_best,
transfer_model_best);
-static int heft_push_task(struct starpu_task *task)
- if (task->priority > 0)
- return _heft_push_task(task, 1);
- return _heft_push_task(task, 0);
-static struct starpu_task *heft_pop_task(void)
- struct starpu_task *task;
- task = _starpu_fifo_pop_local_task(fifo);
- if (task)
- fifo->exp_len -= model;
- return task;
-static void heft_deinit(__attribute__ ((unused)) struct
*_policy)
- _starpu_destroy_fifo(queue_array[workerid]);
- _STARPU_PTHREAD_MUTEX_DESTROY(&sched_mutex[workerid]);
- _STARPU_PTHREAD_COND_DESTROY(&sched_cond[workerid]);
-struct starpu_sched_policy _starpu_sched_heft_policy =
- .init_sched = heft_init,
- .deinit_sched = heft_deinit,
- .push_task = heft_push_task,
- .push_task_notify = heft_push_task_notify,
- .pop_task = heft_pop_task,
- .pop_every_task = NULL,
- .pre_exec_hook = heft_pre_exec_hook,
- .post_exec_hook = NULL,
- .policy_name = "heft",
- .policy_description = "Heterogeneous Earliest Finish Task"
diff --git a/trunk/tests/sched_policies/data_locality.c
b/trunk/tests/sched_policies/data_locality.c
index e77343f..71910b5 100644
--- a/trunk/tests/sched_policies/data_locality.c
+++ b/trunk/tests/sched_policies/data_locality.c
@@ -9,7 +9,7 @@
* test makes sure the scheduler will take account of the data locality
* when scheduling tasks.
- * Applies to : dmda, heft, pheft.
+ * Applies to : dmda, pheft.
static void
@@ -155,7 +155,6 @@ extern struct starpu_sched_policy
//extern struct starpu_sched_policy _starpu_sched_eager_policy;
//extern struct starpu_sched_policy _starpu_sched_pgreedy_policy;
static struct starpu_sched_policy *policies[] =
@@ -163,7 +162,6 @@ static struct starpu_sched_policy *policies[] =
//&_starpu_sched_prio_policy,
//&_starpu_sched_dm_policy,
//&_starpu_sched_dmda_ready_policy,
//&_starpu_sched_dmda_sorted_policy,
//&_starpu_sched_random_policy,
diff --git a/trunk/tests/sched_policies/execute_all_tasks.c
b/trunk/tests/sched_policies/execute_all_tasks.c
index 90ca362..41ceb38 100644
--- a/trunk/tests/sched_policies/execute_all_tasks.c
+++ b/trunk/tests/sched_policies/execute_all_tasks.c
@@ -35,7 +35,6 @@ extern struct starpu_sched_policy
@@ -43,7 +42,6 @@ static struct starpu_sched_policy *policies[] =
diff --git a/trunk/tests/sched_policies/simple_cpu_gpu_sched.c
b/trunk/tests/sched_policies/simple_cpu_gpu_sched.c
index 298d1e6..7034243 100644
--- a/trunk/tests/sched_policies/simple_cpu_gpu_sched.c
+++ b/trunk/tests/sched_policies/simple_cpu_gpu_sched.c
@@ -23,7 +23,7 @@
* - cpu_task is cheduled on a CPU.
* - gpu_task is scheduled on a GPU.
- * Applies to : heft, XXX : and to what other schedulers ?
+ * Applies to : dmda and to what other schedulers ?
@@ -189,14 +189,13 @@ extern struct starpu_sched_policy
_starpu_sched_ws_policy;
extern struct starpu_sched_policy _starpu_sched_prio_policy;
extern struct starpu_sched_policy _starpu_sched_random_policy;
extern struct starpu_sched_policy _starpu_sched_dm_policy;
-extern struct starpu_sched_policy _starpu_sched_dmda_policy;
extern struct starpu_sched_policy _starpu_sched_dmda_ready_policy;
extern struct starpu_sched_policy _starpu_sched_dmda_sorted_policy;
+extern struct starpu_sched_policy _starpu_sched_dmda_policy;
/* XXX: what policies are we interested in ? */
@@ -204,8 +203,7 @@ static struct starpu_sched_policy *policies[] =
//&_starpu_sched_ws_policy,
- //&_starpu_sched_dmda_policy,
+ &_starpu_sched_dmda_policy,
diff --git a/trunk/tests/sched_policies/simple_deps.c
b/trunk/tests/sched_policies/simple_deps.c
index 5142895..9f62df1 100644
--- a/trunk/tests/sched_policies/simple_deps.c
+++ b/trunk/tests/sched_policies/simple_deps.c
@@ -93,7 +93,6 @@ extern struct starpu_sched_policy
@@ -101,7 +100,6 @@ static struct starpu_sched_policy *policies[] =
1.7.10.4
- [Starpu-devel] [PATCH 0/5] Merge heft and dmda., Cyril Roelandt, 28/11/2012
- [Starpu-devel] [PATCH 1/5] dmda*: Add a pre_exec_hook, taken from heft., Cyril Roelandt, 28/11/2012
- [Starpu-devel] [PATCH 3/5] dmda*: take into account the data transfer time., Cyril Roelandt, 28/11/2012
- [Starpu-devel] [PATCH 4/5] dm*: Add StarPU-Top support., Cyril Roelandt, 28/11/2012
- [Starpu-devel] [PATCH 2/5] dmda*: add a push_task_notify method, taken from heft., Cyril Roelandt, 28/11/2012
- [Starpu-devel] [PATCH 5/5] Remove heft., Cyril Roelandt, 28/11/2012
