Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] [PATCH 2/5] dmda*: add a push_task_notify method, taken from heft.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] [PATCH 2/5] dmda*: add a push_task_notify method, taken from heft.
  • Date: Wed, 28 Nov 2012 00:35:09 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
.../deque_modeling_policy_data_aware.c | 58
1 file changed, 58 insertions(+)
diff --git a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
index ab9bc6c..92dc111 100644
--- a/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
+++ b/trunk/src/sched_policies/deque_modeling_policy_data_aware.c
@@ -86,6 +86,8 @@ static struct starpu_task
*_starpu_fifo_pop_first_ready_task(struct _starpu_fifo
fifo_queue->ntasks--;
task = starpu_task_list_back(&fifo_queue->taskq);
+ if (STARPU_UNLIKELY(!task))
+ return NULL;
int first_task_priority = task->priority;
@@ -659,6 +661,59 @@ static void dmda_pre_exec_hook(struct starpu_task *task)
_STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[workerid]);
+static void dmda_push_task_notify(struct starpu_task *task, int workerid)
+ struct _starpu_fifo_taskq *fifo = queue_array[workerid];
+ /* Compute the expected penality */
+ enum starpu_perf_archtype perf_arch =
starpu_worker_get_perf_archtype(workerid);
+ unsigned memory_node = starpu_worker_get_memory_node(workerid);
+ double predicted = starpu_task_expected_length(task, perf_arch,
+ _starpu_get_job_associated_to_task(task)->nimpl);
+ double predicted_transfer =
starpu_task_expected_data_transfer_time(memory_node, task);
+ /* Update the predictions */
+ _STARPU_PTHREAD_MUTEX_LOCK(&sched_mutex[workerid]);
+ /* Sometimes workers didn't take the tasks as early as we expected */
+ fifo->exp_start = STARPU_MAX(fifo->exp_start, starpu_timing_now());
+ fifo->exp_end = fifo->exp_start + fifo->exp_len;
+ /* If there is no prediction available, we consider the task has a
null length */
+ if (!isnan(predicted))
+ task->predicted = predicted;
+ fifo->exp_end += predicted;
+ fifo->exp_len += predicted;
null length */
+ if (!isnan(predicted_transfer))
+ if (starpu_timing_now() + predicted_transfer < fifo->exp_end)
+ /* We may hope that the transfer will be finished by
+ * the start of the task. */
+ predicted_transfer = 0;
+ else
+ /* The transfer will not be finished by then, take the
+ * remainder into account */
+ predicted_transfer = (starpu_timing_now() +
predicted_transfer) - fifo->exp_end;
+ task->predicted_transfer = predicted_transfer;
+ fifo->exp_end += predicted_transfer;
+ fifo->exp_len += predicted_transfer;
+ fifo->ntasks++;
+ _STARPU_PTHREAD_MUTEX_UNLOCK(&sched_mutex[workerid]);
/* TODO: use post_exec_hook to fix the expected start */
struct starpu_sched_policy _starpu_sched_dm_policy =
@@ -678,6 +733,7 @@ struct starpu_sched_policy _starpu_sched_dmda_policy =
.init_sched = initialize_dmda_policy,
.deinit_sched = deinitialize_dmda_policy,
.push_task = dmda_push_task,
+ .push_task_notify = dmda_push_task_notify,
.pop_task = dmda_pop_task,
.pre_exec_hook = dmda_pre_exec_hook,
.post_exec_hook = NULL,
@@ -691,6 +747,7 @@ struct starpu_sched_policy
_starpu_sched_dmda_sorted_policy =
.init_sched = initialize_dmda_sorted_policy,
.push_task = dmda_push_sorted_task,
.pop_task = dmda_pop_ready_task,
@@ -704,6 +761,7 @@ struct starpu_sched_policy
_starpu_sched_dmda_ready_policy =
1.7.10.4
Haut de le page
