Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Merge of sched_ctx branch into the trunk
- Date: Thu, 06 Dec 2012 14:41:37 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Andra, Have you finished to commit your modifications? I just did a svn diff between the 2 branches, and some files differ even though they should not, such as include/starpu_util.h Cheers, Nathalie On 06/12/2012 14:23, Andra Hugo wrote: Ok Nathalie! I would like then to ask you to stop comitting until this happens in order to make my task easier De: "Nathalie Furmento" <nathalie.furmento@labri.fr> À: starpu-devel@lists.gforge.inria.fr Envoyé: Jeudi 6 Décembre 2012 14:19:45 Objet: Re: [Starpu-devel] Merge of sched_ctx branch into the trunk On 06/12/2012 14:18, Andra Hugo wrote: Hello, I would like to finally merge the sched_ctx branch into the trunk. I've done the last merge of the trunk into the branch 2h ago and hydra tests seem good. Is everyone ok with it? Andra _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel I would prefer to wait for the buildbot profiles to pass succesfully. Hydra does not test GPU configurations. Cheers, Nathalie _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Nathalie Furmento, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Cyril Roelandt, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Nathalie Furmento, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Samuel Thibault, 07/12/2012
- [Starpu-devel] Commits are suspended --- Re: Merge of sched_ctx branch into the trunk, Nathalie Furmento, 07/12/2012
