Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Merge of sched_ctx branch into the trunk
- Date: Fri, 7 Dec 2012 10:17:36 +0100 (CET)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
Exactly, there's a huge todo list, and instead of doing this i spend all my
time doing merges every 2 hours.
I have some doubts that someone will ever help me fixing things as long as I
keep my work on a branch.
Andra
----- Mail original -----
> De: "Cyril Roelandt" <cyril.roelandt@inria.fr>
> À: "Andra Hugo" <andra.hugo@inria.fr>
> Cc: starpu-devel@lists.gforge.inria.fr
> Envoyé: Vendredi 7 Décembre 2012 03:59:20
> Objet: Re: [Starpu-devel] Merge of sched_ctx branch into the trunk
> On 12/06/2012 02:18 PM, Andra Hugo wrote:
> > Hello,
> Hi!
> > I would like to finally merge the sched_ctx branch into the trunk.
> > I've done the last merge of the trunk into the branch 2h ago and
> > hydra tests seem good.
> > Is everyone ok with it?
> A few things are still bugging me.
> - there is a *huge* TODO list at
> https://wiki.bordeaux.inria.fr/runtime/doku.php?id=starpu_sched_ctx .
> What about it?
> - hydra isn't really happy: there are more failures in sched_ctx than
> in
> the trunk.
> - scan-build is not happy either. Last time I checked, it found a
> possible NULL-pointer dereference, for instance.
> - there are style issues. We cleaned the code as much as possible for
> 1.0, so I'd like it to stay as clean as possible.
> I've just tried to compile your branch, and it fails with a bunch of
> errors (undefined references to cublas, cuda and pthread functions).
> This error:
> http://hydra.bordeaux.inria.fr/build/127928/download/1/nix-build-b2b358r4bss942v5xjvzb672r30jgbq7-starpu-0.drv-0/starpu-1.1.0/tests/parallel_tasks/parallel_kernels.log
> probably has something to due with the incomplete switch in
> _starpu_can_use_nth_implementation().
> We're almost there, though :) Keep up the good work! I'd be happy to
> help you as much as I can (given the limited amount of time I have
> :p).
> Cyril Roelandt.
- [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Nathalie Furmento, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 06/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Cyril Roelandt, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Andra Hugo, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Nathalie Furmento, 07/12/2012
- Re: [Starpu-devel] Merge of sched_ctx branch into the trunk, Samuel Thibault, 07/12/2012
- [Starpu-devel] Commits are suspended --- Re: Merge of sched_ctx branch into the trunk, Nathalie Furmento, 07/12/2012
