Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
  • Date: Wed, 12 Dec 2012 10:15:01 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
The parallel tests are currently failing when calling
_starpu_can_use_nth_implementation (arch=STARPU_ANY_WORKER, cl=0x617840, nimpl=0)
The function _starpu_can_use_nth_implementation() does not have a case for the value STARPU_ANY_WORKER and ends up with an assert.
Should the function just return 0 when called with STARPU_ANY_WORKER ?
Cheers,
Nathalie
Haut de le page
