Archives de la liste
Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
- Date: Wed, 12 Dec 2012 10:52:04 +0100 (CET)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
I think it should return 1 if there's an implementation for all types of
workers and 0 if there is at least 1 type of worker that does not have an
avaialble implementation.
Andra
----- Mail original -----
> De: "Nathalie Furmento" <nathalie.furmento@labri.fr>
> À: starpu-devel@lists.gforge.inria.fr
> Envoyé: Mercredi 12 Décembre 2012 10:15:01
> Objet: [Starpu-devel] internal function _starpu_can_use_nth_implementation
> All,
> The parallel tests are currently failing when calling
> _starpu_can_use_nth_implementation (arch=STARPU_ANY_WORKER,
> cl=0x617840,
> nimpl=0)
> The function _starpu_can_use_nth_implementation() does not have a
> case
> for the value STARPU_ANY_WORKER and ends up with an assert.
> Should the function just return 0 when called with STARPU_ANY_WORKER
> Cheers,
> Nathalie
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Nathalie Furmento, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Andra Hugo, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Nathalie Furmento, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Samuel Thibault, 12/12/2012
