Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Unable to visualize Paje traces with ViTE
- Date: Thu, 10 Jan 2013 11:20:21 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I'm using StarPU trunk (r8366) compiled without poti support, on a Debian testing x86_64 machine, and am unable to visualize the traces using ViTE.
Is ViTE supported ? If not, could you suggest an alternate program that would allow me to visualize a trace ?
Here are some details about my configuration:
StarPU is compiled with the following configure command:
./configure --with-fxt --prefix=`pwd`/install/ --enable-maxbuffers=1000
(The large NMAXBUFFERS value is normal, if a bit peculiar to my applications).
I'm using the debian experimental libfxt package, as advised by the documentation (as of r8226):
$ apt-cache policy libfxt0
libfxt0:
Installed: 0.2.11-1
Candidate: 0.2.11-1
Version table:
*** 0.2.11-1 0
400 http://alpha/debian/ experimental/main amd64 Packages
100 /var/lib/dpkg/status
0.2.6-2 0
900 http://alpha/debian/ testing/main amd64 Packages
500 http://alpha/debian/ unstable/main amd64 Packages
I'm trying to visualize the traces generated by starpu_fxt_tool using ViTE, and get error messages with both the debian package and the SVN trunk (r1376).
Here is the beginning of the log.txt error file generated by ViTE (debian package version), the rest of the file being similar:
File trace.paje
Errors :
224 : Unknown container: MEMNODE0
225 : Unknown container: 22174
226 : Unknown container: MEMNODE0
227 : Unknown container: 22172
228 : Unknown container: MEMNODE0
229 : Unknown container: 22173
230 : Unknown container: MEMNODE0
231 : Unknown container: 22171
232 : Unknown container: MEMNODE0
233 : Unknown container: 22175
234 : Unknown container: MEMNODE0
235 : Unknown container: 22176
236 : Unknown container: MEMNODE0
237 : Unknown container: 22178
238 : Unknown container: MEMNODE0
239 : Unknown container: 22177
240 : Unknown container: MEMNODE0
241 : Unknown container: 22179
242 : Unknown container: MEMNODE0
243 : Unknown container: 22180
244 : Unknown container: 22177
245 : Unknown container: 22175
246 : Unknown container: 22176
247 : Unknown container: 22172
248 : Unknown container: 22179
249 : Unknown container: 22173
250 : Unknown container: 22174
251 : Unknown container: 22180
252 : Unknown container: 22171
Attached are the first 2000 lines of the paje trace file.
Thank you,
Benoit Lize
trace.head.paje
Description: Binary data
- [Starpu-devel] Unable to visualize Paje traces with ViTE, Benoît Lizé, 10/01/2013
- Re: [Starpu-devel] Unable to visualize Paje traces with ViTE, Samuel Thibault, 10/01/2013
- Re: [Starpu-devel] Unable to visualize Paje traces with ViTE, Benoît Lizé, 10/01/2013
