Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Generating multiple trace
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Xavier Lacoste <xl64100@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Generating multiple trace
  • Date: Fri, 25 Jan 2013 16:02:54 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Xavier Lacoste, le Fri 25 Jan 2013 15:52:31 +0100, a écrit :
> I updated FXT which wasn't up to date.
> I still have a truncated trace of 6762.199584000 ms whereas my job is 100s
> long.
> The prof_file file is about 65 Mo and the paje.trace is only 20Mo.
Did you recompile starpu with the newer fxt? You should have
HAVE_ENABLE_FUT_FLUSH set to 1 in
./src/common/config.h
> When I use starpu_fxt_tool i get many :
> code & 0xff == 0 !!!
> Can this explain the problem ?
That could be a symptom, yes.
Samuel
Haut de le page
