Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Generating multiple trace
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Generating multiple trace
  • Date: Fri, 25 Jan 2013 16:13:40 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 25 janv. 2013 à 16:02, Samuel Thibault a écrit :
> Xavier Lacoste, le Fri 25 Jan 2013 15:52:31 +0100, a écrit :
>> I updated FXT which wasn't up to date.
>> I still have a truncated trace of 6762.199584000 ms whereas my job is 100s
>> long.
>> The prof_file file is about 65 Mo and the paje.trace is only 20Mo.
> Did you recompile starpu with the newer fxt? You should have
> HAVE_ENABLE_FUT_FLUSH set to 1 in
> ./src/common/config.h
Ok that must be my problem, I did rebuild with
LIBS="liberty -lbfd" ./configure --prefix /home/lacoste/starpu-trunk-nocuda
--with-fxt=/opt/cluster/plafrim-dev/fxt-0.2.11 --enable-maxcpus=160
--enable-max-sched-ctxs=30 --disable-cuda --disable-opencl
but I have
/* #undef HAVE_ENABLE_FUT_FLUSH */
in config.h
I'll try to get it defined.
thanks
>> When I use starpu_fxt_tool i get many :
>> code & 0xff == 0 !!!
>> Can this explain the problem ?
> That could be a symptom, yes.
> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
