Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Generating multiple trace
Archives de la liste
Chronologique Discussions
  • To: Xavier Lacoste <xl64100@gmail.com>
  • Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Generating multiple trace
  • Date: Fri, 25 Jan 2013 16:16:01 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 25 janv. 2013 à 16:13, Xavier Lacoste a écrit :
> Le 25 janv. 2013 à 16:02, Samuel Thibault a écrit :
>> Xavier Lacoste, le Fri 25 Jan 2013 15:52:31 +0100, a écrit :
>>> I updated FXT which wasn't up to date.
>>> I still have a truncated trace of 6762.199584000 ms whereas my job is
>>> 100s long.
>>> The prof_file file is about 65 Mo and the paje.trace is only 20Mo.
>> Did you recompile starpu with the newer fxt? You should have
>> HAVE_ENABLE_FUT_FLUSH set to 1 in
>> ./src/common/config.h
> Ok that must be my problem, I did rebuild with
> LIBS="liberty -lbfd" ./configure --prefix /home/lacoste/starpu-trunk-nocuda
> --with-fxt=/opt/cluster/plafrim-dev/fxt-0.2.11 --enable-maxcpus=160
> --enable-max-sched-ctxs=30 --disable-cuda --disable-opencl
> but I have
> /* #undef HAVE_ENABLE_FUT_FLUSH */
> in config.h
> I'll try to get it defined.
> thanks
I re-did my configure step and it seems fine now, I have the define well
set... must have missed one step, sorry.
>>> When I use starpu_fxt_tool i get many :
>>> code & 0xff == 0 !!!
>>> Can this explain the problem ?
>> That could be a symptom, yes.
>> Samuel
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
