Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu_codelet must be global?
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Miguel Palhas <mpalhas@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] starpu_codelet must be global?
  • Date: Tue, 30 Apr 2013 23:23:51 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
The correct way is to use the function
starpu_codelet_init(struct starpu_codelet *cl);
to properly initialise a codelet. All examples provided with StarPU might not
be doing it though. I just updated the documentation to clarify this issue.
Cheers,
Nathalie
On Apr 30, 15:59, Miguel Palhas wrote:
> I'm trying to mess around with the initial examples of starpu, and came
> across a strange error
> The original sample declares a global variable, struct starpu_codelet cl. I
> tried to make this variable local to the main function, basically doing
> this:
> // this is the old variable, commented out
> // struct starpu_codelet cl;
> int main() {
> // and this is the new one
> cl.where = STARPU_CPU
> cl.cpu_funcs[0] = cpu_func;
> cl.cpu_funcs[1] = NULL;
> cl.nbuffers = 0;
> This version crashes with the following error:
> [1] 26482 illegal hardware instruction ./a.out
> but if i just switch the comments and use the global variable instead, it
> all goes well again.
> I'm actually fine with this requirement, i just wanted to know if this is
> to be expected, and why?
> Best Regards
> Miguel Palhas
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
