Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Cc: Mathieu Faverge <Mathieu.Faverge@inria.fr>, Pierre Ramet <ramet@labri.fr>
  • Subject: Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
  • Date: Tue, 10 Dec 2013 10:15:36 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
For the execute_on_worker issue, I'll add a
#define STARPU_EXECUTE_ON_WORKER (15<<16)
And create a patch modifying starpu_mpi_insert_task.c / starpu_insert_task_util.c that i'll send you.
STARPU_EXECUTE_ON_WORKER, workerid, would set workerid and execute_on_a_specific_worker except if workerid is -1.
I have to modify my code to validate my changes before sending the patch.
For the profiling issue maybe I could do an other patch adding #define STARPU_TASKPTR (16<<16)  which would trigger task->destroy=0 and copy task pointer to the given address.
That would give STARPU_TASKPTR, (struct starpu_task **) &(taskptr),
Have a nice day,
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Le 10 déc. 2013 à 09:21, Xavier Lacoste <xavier.lacoste@inria.fr> a écrit :
Hello,
An other question about starpu_mpi_insert_task() :
Is it possible to set the execute_on_a_specific_worker / workerid via starpu_mpi_insert_task() ?
Regards,
XL.
Xavier Lacoste
33405 Talence Cedex
Le 9 déc. 2013 à 17:32, Xavier Lacoste <xavier.lacoste@inria.fr> a écrit :
Hello,
I'm thinking of modifying PaStiX + StarPU source code so that it works with MPI.
As I understand the more convenient way is to use starpu_mpi_insert_task() which will handle all the required communication between nodes.
But if I go from the starpu_task_submit() model to the insert_task model, I cannot get profilling info from my tasks after execution as I have no struct starpu_task anymore.
(I print my profiling info as done in examples/profiling/profiling.c)
Is there a way to use the starpu_mpi_insert_task(), tell StarPU to set the destroy field to 0, and get the generated task to be able to do retrieve some profiling info from it ?
Maybe I could do it through a callback function but wouldn't this increase the computational time before starpu_wait_for_all() returns ?
Have a nice day,
XL.
Xavier Lacoste
33405 Talence Cedex
Haut de le page
