Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Xavier Lacoste <xavier.lacoste@inria.fr>, starpu-devel@lists.gforge.inria.fr, Mathieu Faverge <Mathieu.Faverge@inria.fr>, Pierre Ramet <ramet@labri.fr>
- Subject: Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
- Date: Thu, 12 Dec 2013 22:20:50 +0100
- Authentication-results: iona.labri.fr (amavisd-new); dkim=pass (1024-bit key) reason="pass (just generated, assumed good)" header.d=labri.fr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
The function starpu_mpi_task_build() which has to be used together
with starpu_mpi_task_post_build() is now available in the trunk.
There is an example and some documentation showing how to use them.
Cheers,
Nathalie
On Dec 10, 14:34, Nathalie Furmento wrote:
> I am going to look at a MPI version of starpu_task_build(). It will
> have to be split in 2 calls, but it should not be too difficult to
> implement.
> Cheers,
> Nathalie
> On 10/12/2013 14:27, Samuel Thibault wrote:
> >Xavier Lacoste, le Mon 09 Dec 2013 17:33:02 +0100, a écrit :
> >>Is there a way to use the starpu_mpi_insert_task(), tell StarPU to set the
> >>destroy field to 0, and get the generated task to be able to do retrieve
> >>some
> >>profiling info from it ?
> >You can use starpu_task_build, which works the same as insert_task, but
> >just builds the task, and then you can submit it. We don't have the MPI
> >version for it, but it should be feasible not too hardly.
> >Samuel
- [Starpu-devel] starpu_mpi_insert_task() and profiling, Xavier Lacoste, 09/12/2013
- Re: [Starpu-devel] starpu_mpi_insert_task() and profiling, Xavier Lacoste, 10/12/2013
- Re: [Starpu-devel] starpu_mpi_insert_task() and profiling, Samuel Thibault, 10/12/2013
- Re: [Starpu-devel] starpu_mpi_insert_task() and profiling, Nathalie Furmento, 10/12/2013
- Re: [Starpu-devel] starpu_mpi_insert_task() and profiling, Nathalie Furmento, 12/12/2013
