Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Xavier Lacoste <xavier.lacoste@inria.fr>, starpu-devel@lists.gforge.inria.fr, Mathieu Faverge <Mathieu.Faverge@inria.fr>, Pierre Ramet <ramet@labri.fr>
  • Subject: Re: [Starpu-devel] starpu_mpi_insert_task() and profiling
  • Date: Tue, 10 Dec 2013 14:34:43 +0100
  • Authentication-results: iona.labri.fr (amavisd-new); dkim=pass (1024-bit key) reason="pass (just generated, assumed good)" header.d=labri.fr
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I am going to look at a MPI version of starpu_task_build(). It will have to be split in 2 calls, but it should not be too difficult to implement.
Cheers,
Nathalie
On 10/12/2013 14:27, Samuel Thibault wrote:
Xavier Lacoste, le Mon 09 Dec 2013 17:33:02 +0100, a écrit :
Is there a way to use the starpu_mpi_insert_task(), tell StarPU to set the
destroy field to 0, and get the generated task to be able to do retrieve some
profiling info from it ?
You can use starpu_task_build, which works the same as insert_task, but
just builds the task, and then you can submit it. We don't have the MPI
version for it, but it should be feasible not too hardly.
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
