Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-announce@lists.gforge.inria.fr
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] starpu v1.1.0rc4 released
- Date: Thu, 12 Dec 2013 14:02:49 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
All,
The StarPU team is pleased to announce the fourth release candidate for v1.1.0, the scheduling context release,
https://gforge.inria.fr/frs/?group_id=1570
The tarball along with the md5sum file and the OpenPGP signature are available on the Gforge web site
or on the secondary web site
http://runtime.bordeaux.inria.fr/StarPU/files/
This should hopefully be the latest candidate for v1.1.0. Compared to the rc3, there is many bug fixes for the implementation of the scheduling contexts and the hypervisor. Please test and let us know if you find any issue.
Nathalie, for the StarPU team.
New features:
* Document how to migrate data over MPI.
* Documentation improvment
* Several bug fixes for the hypervisor and the scheduling contexts
* The function starpu_sched_ctx_create() now takes a variable
argument list to define the scheduler to be used, and the minimum
and maximum priority values. The scheduler to be used can either
be defined by its name or by a pointer to an existing scheduler
structure.
* The functions starpu_sched_set/get_min/max_priority set/get the
priorities of the current scheduling context, i.e the one which
was set by a call to starpu_sched_ctx_set_context() or the initial
context if the function has not been called yet.
* When initialising a task, its scheduling context is no longer set,
on submission, it is set to the initial context for internal
tasks, and to the current context for the other tasks.
* New function starpu_wakeup_worker() to be used by schedulers to
wake up a single worker (instead of all workers) when submitting a
single task.
* New function starpu_sched_ctx_register_close_callback() to specify
a callback which will be called when the last task of the context
will finish its execution.
- [Starpu-devel] starpu v1.1.0rc4 released, Nathalie Furmento, 12/12/2013
