Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU CUDA configuration error
- Date: Sat, 14 Dec 2013 21:16:40 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
To whom it may concern,
best wishes,
Linnan Wang
Ph.D Candidate, Mechanical and Aerospace Engineering
School of Engineering
Rutgers, the State University of New Jersey
I'm trying to configure the starpu on my mac. But I got the error message of "whether CUDA is working... CUDA found and can be compiled, but compiled application can not be run, is the CUDA path missing in LD_LIBRARY_PATH?" I tried the following command:
export LD_LIBRARY_PATH=/usr/local/cuda/lib:$LD_LIBRARY_PATH
as well as
export DYLD_LIBRARY_PATH=/usr/local/cuda/lib:$DYLD_LIBRARY_PATH
but they did not work.
Here is my environment:
GCC
Configured with: /private/var/tmp/llvmgcc42/llvmgcc42-2336.11~182/src/configure --disable-checking --enable-werror --prefix=/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2 --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-prefix=llvm- --program-transform-name=/^[cg][^.-]*$/s/$/-4.2/ --with-slibdir=/usr/lib --build=i686-apple-darwin11 --enable-llvm=/private/var/tmp/llvmgcc42/llvmgcc42-2336.11~182/dst-llvmCore/Developer/usr/local --program-prefix=i686-apple-darwin11- --host=x86_64-apple-darwin11 --target=i686-apple-darwin11 --with-gxx-include-dir=/usr/include/c++/4.2.1
Thread model: posix
gcc version 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.11.00)
NVCC
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2013 NVIDIA Corporation
Built on Wed_Jul_10_11:16:01_PDT_2013
Cuda compilation tools, release 5.5, V5.5.0
Configuration File:
checking build system type... x86_64-apple-darwin12.5.0
checking host system type... x86_64-apple-darwin12.5.0
checking target system type... x86_64-apple-darwin12.5.0
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... build-aux/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for ar... ar
checking the archiver (ar) interface... ar
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C preprocessor... gcc -E
checking for a sed that does not truncate output... /usr/bin/sed
checking whether ln -s works... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether gfortran accepts -g... yes
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld
checking if the linker (/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) is GNU ld... no
checking for BSD- or MS-compatible name lister (nm)... /opt/local/bin/nm
checking the name lister (/opt/local/bin/nm) interface... BSD nm
checking the maximum length of command line arguments... 196608
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-apple-darwin12.5.0 file names to x86_64-apple-darwin12.5.0 format... func_convert_file_noop
checking how to convert x86_64-apple-darwin12.5.0 file names to toolchain format... func_convert_file_noop
checking for /usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld option to reload object files... -r
checking for objdump... no
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... no
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /opt/local/bin/nm output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dsymutil... dsymutil
checking for nmedit... nmedit
checking for lipo... lipo
checking for otool... otool
checking for otool64... no
checking for -single_module linker flag... yes
checking for -exported_symbols_list linker flag... yes
checking for -force_load linker flag... yes
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fno-common -DPIC
checking if gcc PIC flag -fno-common -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) supports shared libraries... yes
checking dynamic linker characteristics... darwin12.5.0 dyld
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld
checking whether the g++ linker (/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fno-common -DPIC
checking if g++ PIC flag -fno-common -DPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for gfortran option to produce PIC... -fno-common
checking if gfortran PIC flag -fno-common works... yes
checking if gfortran static flag -static works... no
checking if gfortran supports -c -o file.o... yes
checking if gfortran supports -c -o file.o... (cached) yes
checking whether the gfortran linker (/usr/llvm-gcc-4.2/libexec/gcc/i686-apple-darwin11/4.2.1/ld) supports shared libraries... yes
checking for ANSI C header files... (cached) yes
checking for C/C++ restrict keyword... __restrict
checking for bash... /bin/sh
checking for svnversion... /usr/bin/svnversion
cp: ./STARPU-REVISION and ./STARPU-REVISION are identical (not copied).
checking for lib... no
checking size of void *... 8
checking for pthread_create in -lpthread... yes
checking for library containing sqrt... none required
checking for main in -lws2_32... no
checking for sysconf... yes
checking for pthread_spin_lock... no
checking for pthread_setaffinity_np... no
checking for posix_memalign... yes
checking for memalign... no
checking for drand48... yes
checking for erand48_r... no
checking for strerror_r... yes
checking for setenv... yes
checking for unsetenv... yes
checking for nearbyintf... yes
checking for rintf... yes
checking malloc.h usability... no
checking malloc.h presence... no
checking for malloc.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking for sched_yield... yes
checking whether the target supports __sync_val_compare_and_swap... yes
checking whether the target supports __sync_bool_compare_and_swap... yes
checking whether the target supports __sync_fetch_and_add... yes
checking whether the target supports __sync_fetch_and_or... yes
checking whether the target supports __sync_lock_test_and_set... yes
checking whether the target supports __sync_synchronize... yes
checking for library containing set_mempolicy... no
checking whether libnuma is available... no
checking maximum number of sched_ctxs... 10
checking maximum number of CPUs... 64
checking whether CPUs should be used... yes
checking maximum number of CUDA devices... 4
checking whether CUDA is available in /usr/local/cuda...
checking cuda.h usability... yes
checking cuda.h presence... yes
checking for cuda.h... yes
checking whether CUDA is available with: -L/usr/local/lib...
checking for main in -lcuda... no
checking whether CUDA is available...
checking cuda.h usability... no
checking cuda.h presence... no
checking for cuda.h... no
checking whether CUDA is available with: -L/usr/local/cuda/lib64...
checking whether CUDA is available with: -L/usr/local/cuda/lib...
checking for main in -lcuda... yes
checking for main in -lcudart... yes
checking for main in -lcublas... yes
checking whether CUDA is working... CUDA found and can be compiled, but compiled application can not be run, is the CUDA path missing in LD_LIBRARY_PATH?
no
configure: error: cannot find CUDA
Any help will be appreciated, thank you.
-- best wishes,
Linnan Wang
- [Starpu-devel] StarPU CUDA configuration error, 王楠, 15/12/2013
- Re: [Starpu-devel] StarPU CUDA configuration error, Samuel Thibault, 19/12/2013
