Archives de la liste
- To: <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] StarPU
- Date: Thu, 23 Jan 2014 10:25:20 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi all,
I have a Starpu Application already working on linux. I would like to make it run on windows too. I found the windows project in the following link https://ci.inria.fr/starpu/job/starpu-trunk-windows/, but I didn’t find any documentation or guidelines to compile the project on windows.
Under /bin folder, I found a VisualStudio project which compiles my code, but it doesn´t run if I use any starpu function as “init”. I have set the environment variable STARPU_PATH to the correct folder, and the VS project point to that variable.
Do you know if I have to do any additional step or link any libraries?
I will appreciate if you can help me with this issue.
Thanks in advance, ------------------------------------------------- Antonio Vilches Reina. Phd Student at Department of Computer Architecture University of Malaga
E.T.S.I. Informatica Bulevar Louis Pasteur, 35 29071 MALAGA (SPAIN)
Phone: + 34 952133387 Fax: + 34 952132790 http://www.ac.uma.es/~avilches -------------------------------------------------
- [Starpu-devel] StarPU, Antonio Vilches, 23/01/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 29/01/2014
