Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Antonio Vilches <avilches@ac.uma.es>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU
- Date: Wed, 29 Jan 2014 11:28:16 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi Antonio,
Explanations on how to run StarPU are available in the INSTALL file in the root directory of StarPU source tree. https://gforge.inria.fr/scm/viewvc.php/trunk/INSTALL?view=markup&root=starpu It should be added in the documentation, i am going to do it. What's the contents of your directory $STARPU_PATH? It should be something like: Directory of c:\builds\workspace\starpu-trunk-windows\install &nb sp; &nb sp; AUTHORS   ; &n bsp; <DIR> bin &nb sp; COPYING.LGPL &nb sp; <DIR> include   ; &n bsp; <DIR> lib &nb sp; README &nb sp; <DIR> share & nbsp;&nbs p; STARPU-REVISION &nb sp; &nb sp; Directory of c:\builds\workspace\starpu-trunk-windows\install\lib &n bsp;  ; &nb sp; libstarpu-1.2.a &nb sp; libstarpu-1.2.def & nbsp;&nbs p; libstarpu-1.2.dll.a   ; &n bsp; libstarpu-1.2.exp & nbsp;&nbs p; libstarpu-1.2.la &n bsp;  ; libstarpu-1.2.lib & nbsp;&nbs p; <DIR> pkgconfig &nb sp; <DIR> starpu &nb sp; Cheers, Nathalie On 23/01/2014 10:25, Antonio Vilches wrote: Hi all,
I have a Starpu Application already working on linux. I would like to make it run on windows too. I found the windows project in the following link https://ci.inria.fr/starpu/job/starpu-trunk-windows/, but I didn’t find any documentation or guidelines to compile the project on windows.
Under /bin folder, I found a VisualStudio project which compiles my code, but it doesn´t run if I use any starpu function as “init”. I have set the environment variable STARPU_PATH to the correct folder, and the VS project point to that variable.
Do you know if I have to do any additional step or link any libraries?
I will appreciate if you can help me with this issue.
Thanks in advance, ------------------------------------------------- Antonio Vilches Reina. Phd Student at Department of Computer Architecture University of Malaga
E.T.S.I. Informatica Bulevar Louis Pasteur, 35 29071 MALAGA (SPAIN)
Phone: + 34 952133387 Fax: + 34 952132790 mailto:avilches@ac.uma.es http://www.ac.uma.es/~avilches -------------------------------------------------
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] StarPU, Antonio Vilches, 23/01/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 29/01/2014
