Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Antonio Vilches <avilches@ac.uma.es>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU
  • Date: Wed, 29 Jan 2014 11:51:05 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
The explanation on how to run StarPU applications on Microsoft Visual C has been moved to the README file and is now also available in the general documentation.
https://gforge.inria.fr/scm/viewvc.php/trunk/README?view=markup&root=starpu
Cheers,
Nathalie
On 29/01/2014 11:28, Nathalie Furmento wrote:
52E8D7C0.2050908@labri.fr">
Hi Antonio,
Explanations on how to run StarPU are available in the INSTALL file in the root directory of StarPU source tree.
https://gforge.inria.fr/scm/viewvc.php/trunk/INSTALL?view=markup&root=starpu
It should be added in the documentation, i am going to do it.
What's the contents of your directory $STARPU_PATH? It should be something like:
Directory of c:\builds\workspace\starpu-trunk-windows\install        &nbs p;  &nb sp;
        &nbs p;  &nb sp;
AUTHORS        &nb sp; ; &n bsp;
<DIR>          bin        & amp;nb sp;
COPYING.LGPL        &nbs p;  &nb sp;
<DIR>          include        &nb sp; ; &n bsp;
<DIR>          lib        & amp;nb sp;
README        &nbs p;  &nb sp;
<DIR> share        &nbsp ;& nbsp;&nbs p;
STARPU-REVISION        & amp;nb sp;
        &nbs p;  &nb sp;
Directory of c:\builds\workspace\starpu-trunk-windows\install\lib        &n bsp;  ;
        &nbs p;  &nb sp;
libstarpu-1.2.a        & amp;nb sp;
libstarpu-1.2.def        &nbsp ;& nbsp;&nbs p;
libstarpu-1.2.dll.a        &nb sp; ; &n bsp;
libstarpu-1.2.exp        &nbsp ;& nbsp;&nbs p;
libstarpu-1.2.la        &n bsp;  ;
libstarpu-1.2.lib        &nbsp ;& nbsp;&nbs p;
<DIR>          pkgconfig        & amp;nb sp;
<DIR>          starpu        &nbs p;  &nb sp;
Cheers,
Nathalie
On 23/01/2014 10:25, Antonio Vilches wrote:
Hi all,
I have a Starpu Application already working on linux. I would like to make it run on windows too. I found the windows project in the following link https://ci.inria.fr/starpu/job/starpu-trunk-windows/, but I didn’t find any documentation or guidelines to compile the project on windows.
Under  /bin folder, I found a VisualStudio project which compiles my code, but it doesn´t run if I use any starpu function as “init”.
I have set the environment variable STARPU_PATH to the correct folder, and the VS project point to that variable.
Do you know if I have to do any additional step or link any libraries?
I will appreciate if you can help me with this issue.
Thanks in advance,
Antonio Vilches Reina.
Phd Student at Department of Computer Architecture
University of Malaga
E.T.S.I. Informatica
Bulevar Louis Pasteur, 35
29071 MALAGA (SPAIN)
Phone: + 34 952133387
Fax: + 34 952132790
mailto:avilches@ac.uma.es
http://www.ac.uma.es/~avilches
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
