Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Question about MPI usage
- Date: Fri, 31 Jan 2014 10:53:57 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Nathalie,
Thanks for your fast answer, I forgot what was this parameter for when I
copy/paste the registering code.
Sorry, should have read the manual again ;)
XL.
Le 31 janv. 2014 à 10:50, Nathalie Furmento <nathalie.furmento@labri.fr> a
écrit :
> Xavier,
> When you want to register a data that will be allocated only when it is
> used for the first time, you need to set the "home node", the 2nd parameter
> of starpu_xxx_data_register to -1.
> Cheers,
> Nathalie
> On 31/01/2014 10:46, Xavier Lacoste wrote:
>> Hi,
>> I'm porting PaStiX multicore StarPU code to MPI StarPU.
>> I register on each node local data and halo data (data that willl be read
>> used to update local data or that will be updated using local data).
>> halo data is registered using NULL pointer :
>> starpu_matrix_data_register(&(Lhalo_handle[itercblk]), 0,
>> (uintptr_t)NULL,
>> (uint32_t)HCBLK_STRIDE(itercblk),
>> HCBLK_COLNBR(itercblk),
>> sizeof(PASTIX_FLOAT));
>> starpu_data_set_rank(Lhalo_handle[itercblk], HCBLK_OWNER(itercblk));
>> starpu_data_set_tag(Lhalo_handle[itercblk], HCBLK_GCBLK(itercblk));
>> On the proc that possess the data, the same data is registered with an
>> allocated area (same owner/tag) :
>> starpu_matrix_data_register(&(L_handle[itercblk]), 0,
>> (uintptr_t)SOLV_COEFTAB(itercblk),
>> (uint32_t)SOLV_STRIDE(itercblk),
>> starpu_data_set_rank(L_handle[itercblk], SOLV_PROCNUM);
>> starpu_data_set_tag(L_handle[itercblk], UPDOWN_LOC2GLOB(itercblk));
>> When some tasks are submitted i get this error :
>> [starpu][_starpu_mpi_irecv_data_func][assert failure] Invalid pointer to
>> receive data
>> simple: starpu_mpi.c:487: _starpu_mpi_irecv_data_func: Assertion
>> `req->ptr' failed.
>> When I look into starpu_mpi.c:1422 i found that it is due to
>> starpu_data_get_local_ptr() returns a NULL pointer:
>> if (found_req->user_datatype == 0)
>> found_req->count = 1;
>> found_req->ptr =
>> starpu_data_get_local_ptr(found_req->data_handle);
>> fprintf(stdout, "%s:%d
>> found_req->ptr %p\n", __FILE__, __LINE__, found_req->ptr);
>> I'm certainly doing an error somewhere, do you have any clue ? Is this the
>> NULL pointer i'm giving to starpu_matrix_data_register() ?
>> I don't want to allocate this halo data before i need it... It should only
>> update my local data and be deleted, I was hopping that StarPU was going
>> to do that...
>> Any Idea of what I'm doing wrong ?
>> Regards,
>> XL.
>> PS: As we already gave all informations to starpu_mpi_task_build(),
>> wouldn't it be possible to only give the task to
>> starpu_mpi_task_post_build() ? That would make the code lighter :)
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] Question about MPI usage, Xavier Lacoste, 31/01/2014
- Re: [Starpu-devel] Question about MPI usage, Nathalie Furmento, 31/01/2014
- Re: [Starpu-devel] Question about MPI usage, Xavier Lacoste, 31/01/2014
