Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Question about MPI usage
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Question about MPI usage
  • Date: Fri, 31 Jan 2014 10:46:42 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
I'm porting PaStiX multicore StarPU code to MPI StarPU.
I register on each node local data and halo data (data that willl be read
used to update local data or that will be updated using local data).
halo data is registered using NULL pointer :
starpu_matrix_data_register(&(Lhalo_handle[itercblk]), 0,
(uintptr_t)NULL,
(uint32_t)HCBLK_STRIDE(itercblk),
HCBLK_COLNBR(itercblk),
sizeof(PASTIX_FLOAT));
starpu_data_set_rank(Lhalo_handle[itercblk], HCBLK_OWNER(itercblk));
starpu_data_set_tag(Lhalo_handle[itercblk], HCBLK_GCBLK(itercblk));
On the proc that possess the data, the same data is registered with an
allocated area (same owner/tag) :
starpu_matrix_data_register(&(L_handle[itercblk]), 0,
(uintptr_t)SOLV_COEFTAB(itercblk),
(uint32_t)SOLV_STRIDE(itercblk),
starpu_data_set_rank(L_handle[itercblk], SOLV_PROCNUM);
starpu_data_set_tag(L_handle[itercblk], UPDOWN_LOC2GLOB(itercblk));
When some tasks are submitted i get this error :
[starpu][_starpu_mpi_irecv_data_func][assert failure] Invalid pointer to
receive data
simple: starpu_mpi.c:487: _starpu_mpi_irecv_data_func: Assertion `req->ptr'
failed.
When I look into starpu_mpi.c:1422 i found that it is due to
starpu_data_get_local_ptr() returns a NULL pointer:
if (found_req->user_datatype == 0)
found_req->count = 1;
found_req->ptr =
starpu_data_get_local_ptr(found_req->data_handle);
fprintf(stdout, "%s:%d
found_req->ptr %p\n", __FILE__, __LINE__, found_req->ptr);
I'm certainly doing an error somewhere, do you have any clue ? Is this the
NULL pointer i'm giving to starpu_matrix_data_register() ?
I don't want to allocate this halo data before i need it... It should only
update my local data and be deleted, I was hopping that StarPU was going to
do that...
Any Idea of what I'm doing wrong ?
Regards,
XL.
PS: As we already gave all informations to starpu_mpi_task_build(), wouldn't
it be possible to only give the task to starpu_mpi_task_post_build() ? That
would make the code lighter :)
Haut de le page
