Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Question about MPI usage
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Question about MPI usage
  • Date: Fri, 31 Jan 2014 17:59:38 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello again,
An other question,
I have factorized all my panels (counted it by hand on a small case) -- so I
must have performed all my updates -- and I get this error during the
starpu_wait_for_all() call :
[starpu][_starpu_mpi_progress_thread_func][assert failure] Number of copy
requests left is not zero
(The other MPI process is just waiting for something)
Any clue what it can come from ?
Does that mean that I have received handles that I still need to use ?
Regards,
XL.
Le 31 janv. 2014 à 10:53, Xavier Lacoste <xl64100@gmail.com> a écrit :
> Nathalie,
> Thanks for your fast answer, I forgot what was this parameter for when I
> copy/paste the registering code.
> Sorry, should have read the manual again ;)
> XL.
> Le 31 janv. 2014 à 10:50, Nathalie Furmento <nathalie.furmento@labri.fr> a
> écrit :
>> Xavier,
>> When you want to register a data that will be allocated only when it is
>> used for the first time, you need to set the "home node", the 2nd
>> parameter of starpu_xxx_data_register to -1.
>> Cheers,
>> Nathalie
>> On 31/01/2014 10:46, Xavier Lacoste wrote:
>>> Hi,
>>> I'm porting PaStiX multicore StarPU code to MPI StarPU.
>>> I register on each node local data and halo data (data that willl be read
>>> used to update local data or that will be updated using local data).
>>> halo data is registered using NULL pointer :
>>> starpu_matrix_data_register(&(Lhalo_handle[itercblk]), 0,
>>> (uintptr_t)NULL,
>>> (uint32_t)HCBLK_STRIDE(itercblk),
>>> HCBLK_COLNBR(itercblk),
>>> sizeof(PASTIX_FLOAT));
>>> starpu_data_set_rank(Lhalo_handle[itercblk], HCBLK_OWNER(itercblk));
>>> starpu_data_set_tag(Lhalo_handle[itercblk], HCBLK_GCBLK(itercblk));
>>> On the proc that possess the data, the same data is registered with an
>>> allocated area (same owner/tag) :
>>> starpu_matrix_data_register(&(L_handle[itercblk]), 0,
>>> (uintptr_t)SOLV_COEFTAB(itercblk),
>>> (uint32_t)SOLV_STRIDE(itercblk),
>>> starpu_data_set_rank(L_handle[itercblk], SOLV_PROCNUM);
>>> starpu_data_set_tag(L_handle[itercblk], UPDOWN_LOC2GLOB(itercblk));
>>> When some tasks are submitted i get this error :
>>> [starpu][_starpu_mpi_irecv_data_func][assert failure] Invalid pointer to
>>> receive data
>>> simple: starpu_mpi.c:487: _starpu_mpi_irecv_data_func: Assertion
>>> `req->ptr' failed.
>>> When I look into starpu_mpi.c:1422 i found that it is due to
>>> starpu_data_get_local_ptr() returns a NULL pointer:
>>> if (found_req->user_datatype == 0)
>>> found_req->count = 1;
>>> found_req->ptr =
>>> starpu_data_get_local_ptr(found_req->data_handle);
>>> fprintf(stdout, "%s:%d
>>> found_req->ptr %p\n", __FILE__, __LINE__, found_req->ptr);
>>> I'm certainly doing an error somewhere, do you have any clue ? Is this
>>> the NULL pointer i'm giving to starpu_matrix_data_register() ?
>>> I don't want to allocate this halo data before i need it... It should
>>> only update my local data and be deleted, I was hopping that StarPU was
>>> going to do that...
>>> Any Idea of what I'm doing wrong ?
>>> Regards,
>>> XL.
>>> PS: As we already gave all informations to starpu_mpi_task_build(),
>>> wouldn't it be possible to only give the task to
>>> starpu_mpi_task_post_build() ? That would make the code lighter :)
>>> _______________________________________________
>>> Starpu-devel mailing list
>>> Starpu-devel@lists.gforge.inria.fr
>>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
