Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "Eng.Ahmed Hosny" <ahmed.ibrahim@fci.au.edu.eg>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Building StarPU 1.2 Ubuntu Error
- Date: Wed, 26 Feb 2014 10:00:54 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
It seems to be a problem t with the parser used in the GCC plugin. Disabling the plugin by passing the option --disable-gcc-extensions to configure should be sufficient. Cheers, Nathalie On 25/02/2014 04:59, Eng.Ahmed Hosny wrote: First sorry for duplication but I realized that the first message has no subject and I was afraid from discarding it. Thanks Dear Sir, I'm using Ubuntu 12.1 and I got StarPu from svn. Configuration has been executed successfully. Unfortunately, when typing "Make" on terminal the following error has been appeared make[2]: Entering directory `/home/hosny/Downloads/trunk/build/gcc-plugin/examples' ------------------------------------------------------------- CC hello-starpu.o cc1: error: cannot load plugin ./../src/.libs/starpu.so ./../src/.libs/starpu.so: undefined symbol: _Z7yyparsejPKcPP9tree_node ------------------------------------------------------------ After typing "make check" 3 of 3 tests failed. Attached the log file. I really appreciate your help and fast response. Thanks in advance Best regards, Ahmed Hosny Mohammed Teaching and Research Assistance Computer Science Department Faculty of Computers and Information Assiut University Egypt _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] (sans objet), Eng . Ahmed Hosny, 25/02/2014
- [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Eng . Ahmed Hosny, 25/02/2014
- Re: [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Nathalie Furmento, 26/02/2014
- Re: [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Eng . Ahmed Hosny, 27/02/2014
