Archives de la liste
- From: Eng.Ahmed Hosny <ahmed.ibrahim@fci.au.edu.eg>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] (sans objet)
- Date: Tue, 25 Feb 2014 03:50:39 +0000
- Accept-language: en-US
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear Sir,
I'm using Ubuntu 12.1 and I got StarPu from svn. Configuration has been
executed successfully. Unfortunately, when typing "Make" on terminal the
following error has been appeared
make[2]: Entering directory
`/home/hosny/Downloads/trunk/build/gcc-plugin/examples'
CC hello-starpu.o
cc1: error: cannot load plugin ./../src/.libs/starpu.so
./../src/.libs/starpu.so: undefined symbol: _Z7yyparsejPKcPP9tree_node
After typing "make check"
3 of 3 tests failed. Attached the log file.
I really appreciate your help and fast response. Thanks in advance
Best regards,
Ahmed Hosny Mohammed
Teaching and Research Assistance
Computer Science Department
Faculty of Computers and Information
Assiut University
Egypt
======================================== StarPU 1.2.0: tools/test-suite.log ======================================== 3 of 3 tests failed. .. contents:: :depth: 2 FAIL: starpu_machine_display (exit: 127) ======================================== /home/hosny/Downloads/trunk/build/tools/.libs/lt-starpu_machine_display: error while loading shared libraries: libcudart.so.5.5: cannot open shared object file: No such file or directory #Execution_time_in_seconds 0.037136 ./starpu_machine_display `./starpu_machine_display' exited with return code 127 FAIL: starpu_perfmodel_display (exit: 127) ========================================== /home/hosny/Downloads/trunk/build/tools/.libs/lt-starpu_perfmodel_display: error while loading shared libraries: libcudart.so.5.5: cannot open shared object file: No such file or directory #Execution_time_in_seconds 0.036241 ./starpu_perfmodel_display `./starpu_perfmodel_display' exited with return code 127 FAIL: starpu_perfmodel_plot (exit: 127) ======================================= /home/hosny/Downloads/trunk/build/tools/.libs/lt-starpu_perfmodel_plot: error while loading shared libraries: libcudart.so.5.5: cannot open shared object file: No such file or directory #Execution_time_in_seconds 0.040490 ./starpu_perfmodel_plot `./starpu_perfmodel_plot' exited with return code 127
- [Starpu-devel] (sans objet), Eng . Ahmed Hosny, 25/02/2014
- [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Eng . Ahmed Hosny, 25/02/2014
- Re: [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Nathalie Furmento, 26/02/2014
- Re: [Starpu-devel] Building StarPU 1.2 Ubuntu Error, Eng . Ahmed Hosny, 27/02/2014
