Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Xavier Lacoste <xl64100@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Question about MPI usage
- Date: Tue, 25 Feb 2014 15:41:46 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 25/02/2014 15:21, Samuel Thibault wrote:
Xavier Lacoste, le Tue 25 Feb 2014 15:17:51 +0100, a écrit :I added some code in the trunk and the branch 1.1 to check a data defines a rank when used in a starpu_mpi_task_insert() call.
Le 25 févr. 2014 à 15:07, Samuel Thibault <samuel.thibault@ens-lyon.org> aErf. I meant "node" above, yes. Never a good idea to write a mail in a
écrit :
Xavier Lacoste, le Tue 25 Feb 2014 11:52:21 +0100, a écrit :This data is only defined on proc P because only task executed on proc P can
Thanks, this is due to a read only array that I only register on the nodeAnd no other task will need the array?
which will execute the task.
use it, but there can be multiple task.
rush.
Samuel
Cheers,
Nathalie
- Re: [Starpu-devel] Question about MPI usage, Nathalie Furmento, 03/02/2014
- Re: [Starpu-devel] Question about MPI usage, Xavier Lacoste, 25/02/2014
- Re: [Starpu-devel] Question about MPI usage, Samuel Thibault, 25/02/2014
- Re: [Starpu-devel] Question about MPI usage, Nathalie Furmento, 25/02/2014
