Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] GPU issue with r12137
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] GPU issue with r12137
  • Date: Fri, 28 Mar 2014 07:43:35 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I noticed a regression with starpu 1.1 together with PaStiX.
When I use a GPU (plus 11 CPUs) I get numerica errors in my results.
To reproduce this you can go on mygale and copy :
~lacoste/ricar/src
~lacoste/starpu.git/loadEnv
~lacoste/starpu.git/test.sh
You just have to source loadEnv and update test.sh to your configuration.
> bash test.sh
 should retrun 0 is the test is valid 1 either (or 125 if an other error occured).
I did a bisection this night and the result was :
8d31273ef44a90aa8f3fba282af5b17e08a6cf67 is the first bad commit
commit 8d31273ef44a90aa8f3fba282af5b17e08a6cf67
Author: thibault <thibault@176f6dd6-97d6-42f4-bd05-d3db9ad07c7a>
Date:   Thu Jan 30 12:44:00 2014 +0000
    backport r12137 from trunk: Use different streams for gpu-gpu transfers
    git-svn-id: svn+ssh://scm.gforge.inria.fr/svnroot/starpu/branches/starpu-1.1@12138 176f6dd6-97d6-42f4-bd05-d3db9ad07c7a
:040000 040000 967f352b1e0c64e6aade640ce8f29aacdffebdcd 50c8525dcee5d4067b7121d5c09e82eb6c5d163c M      src
bisect run success
Regards,
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Haut de le page
