Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] GPU issue with r12137
- Date: Fri, 28 Mar 2014 08:31:56 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
There was a mistake in the exports in loadEnv, I just updated it, it should be fixed.
A precision also it's not r12137 but 12138 (it's backport in starpu1.1) which is broken...
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Le 28 mars 2014 à 07:43, Xavier Lacoste <xavier.lacoste@inria.fr> a écrit :
Hello,I noticed a regression with starpu 1.1 together with PaStiX.When I use a GPU (plus 11 CPUs) I get numerica errors in my results.To reproduce this you can go on mygale and copy :~lacoste/ricar/src~lacoste/starpu.git/loadEnv~lacoste/starpu.git/test.shYou just have to source loadEnv and update test.sh to your configuration.> bash test.shshould retrun 0 is the test is valid 1 either (or 125 if an other error occured).I did a bisection this night and the result was :8d31273ef44a90aa8f3fba282af5b17e08a6cf67 is the first bad commitcommit 8d31273ef44a90aa8f3fba282af5b17e08a6cf67Author: thibault <thibault@176f6dd6-97d6-42f4-bd05-d3db9ad07c7a>Date: Thu Jan 30 12:44:00 2014 +0000backport r12137 from trunk: Use different streams for gpu-gpu transfersgit-svn-id: svn+ssh://scm.gforge.inria.fr/svnroot/starpu/branches/starpu-1.1@12138 176f6dd6-97d6-42f4-bd05-d3db9ad07c7a:040000 040000 967f352b1e0c64e6aade640ce8f29aacdffebdcd 50c8525dcee5d4067b7121d5c09e82eb6c5d163c M srcbisect run successRegards,XL.----------------------------------------Xavier LacosteINRIA Bordeaux Sud-Ouest200, avenue de la Vieille Tour33405 Talence CedexTél : +33 (0)5 24 57 40 69
- [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 28/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 28/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 31/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 31/03/2014
