Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] GPU issue with r12137
- Date: Mon, 31 Mar 2014 15:31:27 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
I applied the patch on top of starpu-1.1 (r12511) and this seems to work.
Thanks,
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Le 31 mars 2014 à 15:01, Samuel Thibault <samuel.thibault@ens-lyon.org> a écrit :
Xavier Lacoste, le Fri 28 Mar 2014 15:42:51 +0100, a écrit :I don't see any reason why a commit called "Use different streams for gpu-gpu
transfers" would alter a mono-gpu execution....
Well, actually there is also another change in it: we also make all
threads able to use streams, not only the GPU-driving threads. Could you
try the attached patch, which reverts just that? I'm afraid that means
diving into a CUDA bug, I don't see what is wrong in us doing that.
Samuel
<patch.txt>
- [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 28/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 28/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 31/03/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 31/03/2014
