Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] GPU issue with r12137
- Date: Wed, 2 Apr 2014 16:46:24 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
This doesn't seem to fix the issue.
(Had to manually apply some part of the patch (some was rejected, maybe because of git-svn) but I don't think I mis-applied it)
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Le 2 avr. 2014 à 12:56, Samuel Thibault <samuel.thibault@ens-lyon.org> a écrit :
Xavier Lacoste, le Mon 31 Mar 2014 15:31:27 +0200, a écrit :I applied the patch on top of starpu-1.1 (r12511) and this seems to work.
Ok. I discussed a bit with Cedric about it, he thinks it could be a mere
threadsafety issue in CUDA. Could you try the attached patch instead?
Samuel
<patch.txt>
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 02/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 02/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 03/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Samuel Thibault, 03/04/2014
- Re: [Starpu-devel] GPU issue with r12137, Xavier Lacoste, 04/04/2014
